faceplate screw advice please
ken chase
>After problems with phillips head screws I want to use only square head
and need advice where to get them and what type to use. I currently only have a three inch plate. A problem has been the need to use a long drill bit because the short bit causes the drill to get in the way and not allow a straight hole. I bought hex head screws but couldn't use them for the same reason. Are there hex drivers with a long shaft?
Thanks
Re: faceplate screw advice please
Darryl Hansen
>Yes get one of those Balck and Decker 1/4" dirve kits at Lowes. There will be a magnetic holder for bits in the kit along with drives. Cheeeep and works...
Ken the source is:
TDaniel
>McFeely's.
www.McFeelys.com
order the 3" or 4" long bits to avoid the problem with the chuck getting in the way. I prefer the #12 screws although the #10 may be better for small lathe work.
TD
JKJ in East TN
>You can buy a magnetic bit extension from HD or any hardware store. These come in various lengths from just a few inches to very long. You can buy long bits but they are more expensive and with one extension, you'll never need to.
BTW, don't use drywall screws - they are brittle. I like the square drive deck screws (the tan or green, not the galvanized). Sheet metal screws also work well, but I haven't seen them in square drive. For hard, dry woods it helps to predrill pilot holes. For green wood, I just drive the screw.
Metal siding screws
Roger Smith
>I have had a lot of success using the screws that are used to install metal roofing and siding. The screws are hexhead and have a skipgap type of thread. I did remove the washer with the rubber seal.
roger
Re: Ken the source is:
>Ditto to what Terrysays. I also drill more holes in my faceplate so that I have more screws to hold the piece.
Jim Pugh, Ohio
>Ken, I also prefer the square drive screws. Get the #2 driver size (standard) and about a 3" long driver. I have been using the washer head screws now for some years. For smaller pieces I use the #8 size by 1" long. Also have some that are 1 1/4" and 1 1/2" long - depending on the size of the blank.
As suggested McFeely's is the mail order source or if you have a Rocklers anywhere nearby they also carry the screwdrive screws.
jeff jilg
>I use #10 or #12 stainless hex heads. The stainless screws are hard as heck and the heads won't snap off. Plus I can drive them with a hex head extension.
You probably should the tailstock for initial support during the roughout process. Turning between centers is a very stable process.
Re:Thanks all faceplate screw advice
ken chase
>Ken, you may be right to go with square drive screws, but what I have used lately for the few I still mount on a face plate is those blue screws they have a the big box stores that are meant to drive directly into concrete. They have Phillips heads and are very hard and very tough. They are expensive, but still only a couple of bucks for enough to last a long time. I think they come in several lengths also. I don't have any experience at driving square drive screw over and over, but I bet these would do as well or better. In either case, get an excellent driver that fits exactly. Many Phillips screws fail because the driver does not fit or wears out. With the right tip you should be able to insert the screw on the driver and hold it horizontal or even pointing downward. With a magnetic one you can point it straight down. These screws are fat and I had to drill out the holes in the face plate and I counter sunk them a little to let the screws sit better.
