Union Jubilee Lathe
Union Jubilee Lathe
Union Jubilee Lathe
Randy in Langley
>I was given a Union Jubilee Lathe by a very generous fellow woodworker. He didn't see himself restoring the lathe and he knew that I was looking long and hard at upgrading from my current lathe and since I'm a bit of a "Salvage Collector", I likely had some parts for it. A couple of weeks stripping and painting, wiring and fabricating and I now have the means to swing a 20" bowl or platter with complete speed control. Next is making a banjo and tailstock for it. Woodworkers are the nicest people.
Here's the way it looked when it arrived.
And how it looks now
Thanks for looking
Re: Union Jubilee Lathe
Ooops red X
Randy in Langley
>Here's the before.
Thanks for looking. Anyone know of a place for spare parts for a Union Jubilee Lathe?
Wow Randy
TDaniel
>the paint sure made a difference! Nice looking lathe now. I hope you find the parts to get it going. Let us know when she is running!
TD
georgetroy
>Pretty nice there Randy. Might try this on Banjo. You need to measure to see what your spindle height is. I would guess 6". Anyway now measure between your bed underneath where a washer or spacer would go. In other words another banjo might work if you had needed dimensions. Check other lathes. Height of tool rest post is also important. GT
Gary Evans Tallassee, TN
>Just to add to George's comments.
Take a look at any cross castings under the ways. Their height could mean modifying the nut that holds the banjo to the ways. DAMHIKT
Gary
A little added info
Randy in Langley
>Guys,
I should have probably mentioned that the lathe is up and running on the outboard side. I have some toolrests made up and can turn on the outboard. In the process of modifying the lathe I increased the height of the lathe because it sat too low for my liking, since I added a foot to the tower to increase the spindle height I decided to offset the bed of the lathe by that distance of 5", so the swing over the bed was 10" and is now 20" total. I've looked at various manufacturers for a replacement tailstock and banjo for a 20" swing. Most aren't willing to sell a tailstock by itself and I don't think $300 for a banjo is worth the money. I have a chunk of Silver maple on the outboard end of it now, I'll post some pictures as I progress. I'm not sure what I want to do with the piece so it will take me some time and I may ask for suggestions.
Here's a side shot of the lathe. You can see the sand filled "Foot" sitting on "Hockey Pucks" as adjustable feet for the tower, as well as the "Offset plate" between the tower and the bed of the lathe. You can also see my Vacuum Chucking system I made for the lathe.
Thanks for looking and the feedback, all of it is appreciated.
Brad Vietje
Beautiful machine !
Brad Vietje
Re: A little added info
georgetroy
>Post extenders are made by General, you can check and see if they will sell you one. I know because one came with my riser block kit for the General 260.
