ADVERTISE HERE - FREE TRIAL
2 speed bandsaw
2 speed bandsaw
2 speed bandsaw
bill dotten
>I am setting up my new Delta 18" industrial bandsaw. It has two pulley speeds on the 2 horse motor-Nothing in owners manual about 2 speed usage.
Why is that? metal cutting, butchering, resawing, or just showing off?
Stumped in VA.
BILL
Re: 2 speed bandsaw
Re: 2 speed bandsaw
Jim Ketron
>Hey Bill I seen that Saw in the back of your truck but ya ran off to fast for me to get a look at it. How ya like it so far? Mine has 2 speeds also I just leave mine on the hi speed(3,200) mine is mainly used for green bowl blanks.
The lower speed(1500)is used for Dense hardwood and for more detailed, intricate cuts.
Re: 2 speed bandsaw
Re: 2 speed bandsaw
JKJ in East TN
>I don't know about that Delta, but ferrous metals are cut at a much slower speed than wood. Cutting metal can be very messy, often requiring lubrication, so it would be difficult to use the same saw for both. (I keep a separate drill press to keep the wood away from the metal mess.)
Another warning about cutting metals and wood on the same saw - sparks from metal-cutting can ignite sawdust accumulated inside the saw.
The handbook indicates that changing the speed is also useful for cutting wood, for example a courser blade can be used with a higher speed and a slower speed might be used to cut thicker stock, especially with an underpowered saw since the slower speed pulley will give more torque.
The Band Saw Handbook indicates the average speed for wood is between 2600 and 3100 feet per minute, up to 5000 fpm for large industrial saws. Metals are cut at 40 to 400 fpm. Nonferrous metals (aluminum, copper, brass) can be cut at higher speeds. You might measure the pulleys and drive wheel and calculate the cutting speed for each step. This should give you a hint as to the intention use of the speed range.
Re: 2 speed bandsaw
Re: 2 speed bandsaw
bill dotten
>Hi Jim I set it up the next weekend and found a crack in a casting which I probably caused with the strapping I secured it with.
I am awaiting the casting to complete the tweaking-should be here tomorrow. Haven't sawn anything yet but am blown away with the balance quietness and smoothness. I hope you will be making pens for troops Saturday. I plan to go.
Bill
Re: 2 speed bandsaw
Re: 2 speed bandsaw
bill dotten
>The two speeds do not seem separated enough to allow wood and metal to be sawn. I agree with reasons not to saw metal.
1975 Sears manuals show 18" bandsaws equiped with a gear shift that provided 4 blade speeds from 3550 ft/min down to 118 ft/min for mild steel. I don't know if they offer that any longer.
Thanks
Bill
