We value your privacy.
>Hollow form about 8" across. I am told this wood is from Bulgaria, and is very rare. It was expensive....I turned this about a year ago, and it hasn't turned brown yet.
The finial, 5" tall, is ebony, threaded into the collar. The finish is Bush Oil. I am trying to balance the low form with the tall finial...any comments?
>I think this looks like a good balance Keith. Is that an ebony foot on the bottom or am I just seeing a shadow?
How many coats of Bush oil did you use? I got some up at Saratoga and haven't had a chance to experiment with it yet. How would you compare it to Watco?
Great work here, I like all the details on the finial
>Hi Ed, Thanks, two coats on the form, no finish yet on the finial. The Bush oil has more solids that the Watco. I'm pretty impressed with it. The foot is not visible, but not ebony.
>Hi George, Thank You! No need to be envious....a lot of people have trouble with finials, but there is a secret.... if you look at this one, it can be broken down into seperate elements...there are at least three individual forms in the finial that could stand alone. The very tip of the finial is an inverted form, as is the bulge in the stem. Each of these forms has an emphasis point, just as a hollow form would. To complete the finial, beads and coves with a fillet between each connect all the elements.....classis spindle turning!
Another secret is what I call "definition"...the difference in diameters between the elements. Without definition, the finial will appear very boring and static. This one goes from about an inch at its largest, to under an eighth at the smallest.
>Keith, that rates right up there with Cindy Drozda's work. I think she is one of the best at turnng finials and making them look right. How does turning Ebony compare to turning African Blackwood? I've turned a little African Blackwood and loved it. I never turned Ebony, but have a small piece I'm saving for something special.
>Hi tek, When I showed this one to my wife ( my biggest critic) she replied " bah...too much like Cindy Drozda's work". I like turning ebony, it's very strong. I can turn this stuff to under a 1/16th...too fragile to sell though. It's not as oily as blackwood, and not quite as hard. Another good finial wood is pink ivory, hard and takes great detail. thanks for the comments!
>I wouldn't be insulted if someone told me my work looked like Cindy's. Cindy might be insulted though! ;) Sometimes my work looks like it's done by someone famouse too! Mr. Magoo!
>My only question about these thin finials is what you do to keep a one like that for a year without breaking it. Obviously, you have kept it locked up, never taken it to a show, never shipped it to a symposium, never put it in a gallery, and never sold one of them that somebody had to get home in one piece.
Galleries and open shows are the worst place for a finial because very few people can resist the temptation to tweek the finial and see how fragile it is. I tried thicker finials, but that only made them tweek harder.
This is a serious question. My luck with thin finials hasn't been very good. My solution was to quit making them.
Considering the size of the finial, in my opinion, it could have been a little thinner at the upper end. Or something like a cove/v-vut/enything just below the upper body, that would also influence the 'thin' look.
>Hi Russ, I should have clarified...I rough turned the base about a year ago, as it was green. It never turned brown for that duration. I recently finish turned it and added the finial.....which I turned and then immediately photographed. No finish on it yet.
This piece, along with several others, is bound for a NYC area gallery. I expect the galleries that show my work to take reasonable care of the pieces in their posession....
These finials are stronger than they appear....the only way to break one isintentionally. In that case, it belongs to whoever broke it. Period. I use blackwood, ebony, pink ivory or cocobolo since they are strong woods. All my finials are interchangeable....if a customer accidentally breaks one, I can send them a new one. (I made a threading jig for the threaded portion, so they are all uniform.
Consider glass art...far more fragile than the work we do....yet people collect it. They realize reasonable care is required.
>Thanks Ronny. The neat thing about finials is.....the possibilities are endless! I turn a small finial or spindle each day just to warm up...or a goblet...I'll post a "fancy" goblet soon.
