want to make my first pen
Arw01
>Don't have a lathe proper, but do have a router crafter which I can either spin up with a hand drill, or actually use with a router.
What is the minimum equipment I need to have to use a simple pen kit to make my first pen?
I know I will need to buy a 7mm drill bit, but what after that?
Thanks
Alan
Re: want to make my first pen
Carles in Barcelona
>Hi,
Two good links:
http://www.woodturner-russ.com/Pen10.html
http://www.penturners.org/
Un saludo,
Carles.
eaglesc
>I believe you can go to the Rocklear site( at least it used to be there,) and there is a link that shows you how to make a pen on a drill press.
How good are you at whittlng?:>)
Arw01
>I've ordered the Pen Making DVD from Penn State Industries. Will see what all is on there for information in a few more days. Believe I will check with my local machine shop to see what they have for 7mm drill bits, and I already have a 10mm bit for SOSS round hinges.
Perhaps they have a Pen Mill to straighten the blank to the tube and I will be most of the way there.
