We value your privacy.
>does not work and lathe is on all the time. I unplugged it and when I plugged it in again it threw the breaker. I will call oneway tomorrow, but in the mean time does anyone have any ideas? It is a 1224 lathe and have had it for 6 yrs without any problems.
Without being there to do some checks it is very hard to say. Something you can look at would be the wires. Unplug the lathe from the wall and check all the wiring to make sure there is not a pinch or cut in the rubber jacket. Also look at the connections from the box under the bench as you might have shoved something against the connectors and with vibration it could break the wires right at the connector. As long as the wire look prefect then it might be part of the electronics. Is yours the 220volt or the 110volt unit?
If you are blowing the breaker when you plug it into the wall you have a short somewhere.
>mine is 120volt. I just checked the wires and they seem to be intact and the shelf beside the motor is clear with all the supplies etc at the other end.
>Hey Gary, I had a similar problem with my 1224 (110 also). I didn't blow the breaker, but when I'd flip the switch to start up the main power the light would flicker and eventually hold solid, but other times as soon as I hit the green power button the lathe would click off. It was occasional for a while, and then just went ka-put altogether. I called Kevin at Oneway and described the problem. He said it was the switch that went bad. They apparently got a bad batch back a few years. He said I could do one of two things. Either replace the switch, or disconnect the switch and wire nut the black wires together, and wire nut the white wires together, then plug the lathe into a power strip and use it's on/off switch to power up/down the lathe. I originally wanted to just replace the switch, but I couldn't find the right kind of switch anywhere near me (Radio Shack doesn't have one), and the only other electrical supply store around was a pain to get to. Kevin said the switch was under warranty, but it would take about 5 days to get to me. I was impatient and didn't want to wait that long.
As a result I just went to the store and got a power strip and some wire nuts. Worked like a charm. I now have no problems firing up the little guy, and I also have a couple extra outlets available at the power strip.
If this sounds like the same problem you have give it a go. Since you have a breaker blowing it could be something different though.
>Molly thanks for your experience. I will ck with oneway tomorrow and maybe I will be doing the same thing that you did. See you at the meeting thursday.
I miss read your post. I didn't see that the lathe was running (turning) and would not shut off. It could be a couple of things. I am sure you will get the information you need from Oneway.
Sounds like the start button might be on all the time. Turning off the controller then holding the start button on before the unit is finished the self test and power on sequence could result in the unit popping the breaker. These controllers can be wired a few different ways and I am not sure which way the 1224 is wired.
If you are unable to get the infor from Oneway email me and I will look into mine and see what I can recommend for you to try.
