Wet Bloodwood?
Wet Bloodwood?
Wet Bloodwood?
Bruce McElhaney Spring Lake, MI
>Had a nice piece of Bloodwood square stock for a few months that was supposed to be dry, and seemed to be. Thought I'd make a Peppermill with it. Turned it round and drilled it out and found that it's still damp inside. What should I do with it? Go ahead and make the peppermill or try to dry the wood somehow. I hate to mess it up now. I need Help! Thanks, Bruce
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Jim King
>Bloodwood as with most tropical woods can be laying around 10 years and if it is over 2 inches thick it will probably be wet inside. We work with it everyday and the easiest way to dry it quickly is just put it on the stove and boil it a couple of hours after it is rough turned. It will be bone dry in 10 days. The thing I try to get across to people is that tropical woods are not normaly kiln dried unless in boards. The kiln schedule for 4 inch thick dense tropical woods is months in the kiln and no one is really going to do that but most say they do. Tropical woods from my 20 plus years working with them I have found the best solution I have seen is they should be turned rough wet and boiled immediatly. Tropical woods are not to be set on the shelf and admired as collectors items and let to dry unless you want tooth picks. When you get it , turn it immediatly and make believe it is a lobster and throw it in the pot. I just took a photo today of our boiling pot for our new web site we are building. It looks a bit nasty as we boil 6 to 8 bowls a day.
Re: Wet Bloodwood?
Re: Wet Bloodwood?
.Bob R
>Jim
I have been in the hospital for the last few days and a lot of friends have been dropping off wood which is from who nows were. How do I figure out how long to boil????
Bob R West Mac Turning
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Jim King
>Bob: We normally try to boil at a MINIMUM an hour per inch but if the fire keeps going for three or four hours it does no harm. As I can understand the boiling simply takes out the sticky sap and replaces it with simple water which dries in a few days. I dont know if you could boil it to long but we have had the pot full and kept adding water for several hours and the results are all good.
Re: Wet Bloodwood?
Re: Wet Bloodwood?
>You boil the blanks before sending them, right?
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Jim King
>JL: Is the process I described above I am referring to the rough turned blanks turned down to 1 to 2 inches thick. And yes we have species that we boil in square blanks also to prevent cracking. We are now experimenting with boiling and drying gunstock blanks out of some of the high figure woods. Never having really worked with North American or African woods I cannot say much but I would certainly think boiling ebony, pink ivory and some of the other extremly delicate woods would be benificial.
Re: Wet Bloodwood?
Re: Wet Bloodwood?
McKay Sleight from Utah
>So Jim, where is this web page? You have solved many problems for me already. I have tried unsuccessfully to bend blood wood after steaming. I am wondering if boiling the wood and then steaming or bending after boiling would work. Any ideas? Thanks
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Jim King
>McKay: I have never tried to bend bloodwood by boiling as it is not one of my favorites but we have successfully boiled and bent 1/4 inch by 2 inch slats of other dense species to make woven chair backs.
I am definitly steam bending the rules by posting my web site but here is the temporary connection we are using to work back and forth on the unfinished design with the web site man in Canada.
http://www.furnacefishmedia.com/clients/exoticwood/index.htm
After the site is done it will be again www.exoticwoodworld.com as it is now. We hope to be done with the new one in a couple of weeks.
If anyone has any comments or suggestions I would appreciate them. I dont know if I like it or not but there is still a lot to do.
Jim
Re: Wet Bloodwood?
Re: Wet Bloodwood? Follow up.
>Thanks for the info, Jim. It's very helpful. I'm going to try boiling my Bloodwood peppermill blanks. I've got one of those outdoor turkey boilers/fryers that might be suitable for boiling blanks. After the boiling process is finished, do you store the blanks in any particular way for drying? I've read where some people put tape on one side of the blank, or put them in paper bags, or use other special methods for the drying phase. Also, I have some fresh Apple Wood, that I'm trying to dry. Do you think boiling Apple Blanks would work OK? I've heard Apple is very prone to cracking.
Re: Wet Bloodwood?
Jim King
>Bruce: Just be sure to let the wood cool down to room temperature in the water. DONT take it out before the water cools with the wood in it. Just set it in a shady place in the shop and in 10 days it should be bone dry.
I dont have a clue about apple wood but the method works on tropical fruit woods. If you throw in a piece of apple wood I think a lot of people would be interested in your results.
Jim
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Bill Neddow
>Jim, what a beautiful website. It was a pleasure to browse through. I can hardly wait for all the various species to be photographed. I would love to get some of these woods, but I am in Canada.
Re: Wet Bloodwood?
Re: Wet Bloodwood?
Jorge Castaneda
>McKay and Jim,
I live in an island on the Atlantic ocean, the main industry is lobster fishing, the traditional lobster trap is based in 3 - 1" square bows bent right after boiling them for about 2 hours, to the bending form right from the boiling water, the bows are a little longer than needed and a lath is nailed on the waste to prevent spring back, or a wire preventer is used too instead of the lath, then put aside to free the bending form, we used to bend at least 100 bows in a sesion; after bending we left them hanging to dry inside the shop a week before using in a trap, they still spring back some when the preventer is removed, so the form is actually a more severe bend than needed. No matter how careful you are, there is always a percentage or broken bows, 5-10%.
The bows are made of green red oak, quarter sawn, if the wood has not perfectly straight grain, vertical to use the local parlance, it brakes, the bows made from wood right next to the cambium layer bend the best, the outside on the tree to the inside in the bow.
Now they use wire traps coated in plastic...
$0.02
Jorge
ps, the red oak turns black on the outside when boiled, for the traps it does not matter, but for furniture, you are going to need to shave a little all around.
Re: Wet Bloodwood?
JKJ in East TN
>Bruce,
I have a TXT file I've been accumulating with info on boiling. It includes and excellent article by Steven Russel - http://groups.google.com/group/rec.woodworking/msg/8a6868952124f43b? - and messages from this and other message boards.
If you want a copy of my text file, send an email.
Re: Wet Bloodwood?
Gary Evans Tallassee, TN
>Hi John,
Could you send me a copy of that file? I'd be interested in reading it.
By the way, I brought some wood back for you from the NC show. Send me an e-mail.
Gary
