Sanding Disc Holder Help Needed
Brian McKearney
Brian McKearney
>I have a "Pro Velcro Disc Holder" from Packard Woodworks (see picture below) that I used to power sand my bowls and it is coming apart. Looks like it is made up of two pieces of foam - one is attached to the post that inserts into the power drill, and the second layer of foam is glued to the base. This glue joint is coming apart.
Has this happened to anyone else, and does anyone know what would be the best type of glue to use to glue the two pieces of foam back together? I'll probably order a new one from Packard, but in the meantime, I thought that regluing the joint might get me through a few more bowls.
Any suggestions for what type of glue would work best?
Brian
Re: Sanding Disc Holder Help Needed
AnthonyY
>It happens all the time, I use CA.
>Contact cement works. The particular joint is under stress, so a more "elastic" glue (maybe even rubber cement) should work fine.
jared
>remove 1 for email
I used some 5 minute epoxy because I had some handy. I didnt think it would hold up due to flexing but it has lasted a long time. Jared
Brian McKearney
Brian McKearney
>Thanks for the suggestions - I gave contact cement a try and it looks good as new. I'll see how it holds up as soon as I can find some time at the lathe.
Brian
Denis Lalonde
>Rubberrized CA glue is now available for doing this type of gluing...
Joe Herrmann
>Bruce Hoover (who sells a lot of sanding equipment and pads) recommends something called GOOP. It's available at major craft suppliers like Michaels, etc.
Joe
Steve Worcester
>I used to do it with GOOP, but it will make the pads more firm. They are actually made with industrial contact cement.
What I find interesting, after I have sold hundreds of these, is very few separate between the rubber, and generally because of abuse (although we replace them anyway), but there have been some batches that had bad glue in manufacturing and the velcro will peel off the face. It has been awhile so I don't know if Packard's had any of those batches or not. (They are made by Tim Skilton in Australia.)
Steve Worcester
www.turningwood.com
