Pentarsia
eaglesc
>One for giving A.K.A. The Cathedral
Walnut,cherry and mahogany stones and mortar segmented spiral
Dyed veneers, bubing trim for window
Baron TG
Pentarsia
eaglesc
Baron TG
UNbelievable!!!!!
Jack Savona
>That has got to be your best ever!
Re: Pentarsia
>That is absolutely incredible. You should let me do some macro photography of the details. I can get really really close.
Re: Pentarsia
eaglesc
>Thanks John, maybe on another.
This one is earmarked for an auction.
Since this was originally a test there are mechanical flaws I want to correct in future ones.
These flaws are not evident in the picture and only a penmaker would "discover" them.
There are some glue joints that are not as tight as I would like them.
BTW there is another "window" on the opposite side so lefties won't be "left" out.
Re: Pentarsia
Ed Kelle
>That is amazing. I'd be terrified just drilling thru the blank after glue up. Fantastic work!
Re: Pentarsia
eaglesc
>"I'd be terrified just drilling thru the blank after glue up. "
And you think I Wasn't?
Wow!
Eddie Pacheco; San Jose, Ca.
>How did you hold and cut the segments? Those bands look like they are about 1mm thick. Did you use a veneering saw and Japanese pull saws? Was the glue up of the blank done in segments (no pun intended) as you had to wait for the adhesive to cure a bit to give you someplace to hold the blank.
That is really a piece of art even if you say it has some "flaws".
Re: Wow!
eaglesc
>All cuts made on a tablesaw or scroll saw.
A LITTLE bit of razorblade work but nothing where it was critical.
No clamps used all done with CA and fingers
Re: Pentarsia
Ron in Drums PA
>Most Excellant Eagle.
Re: Pentarsia
Jim Shaver - Oakville, Ontario
>That is so cool!!
take care,
Jim
Impressive
tek-Brunswick, Ohio
>You say it's all glued with CA and fingers? Where are the fingers glued in? If I made it the fingers would definitely be glued to the wood. You must be PENtacostal! Seriously fantastic!
Tom
Amazing!
Bob Hackett
>You really ought to consider submitting a pic to one of the leading WWing mags for thier gallery/reader`s work section.Your work needs to be seen by a wider audience.It really is an inspiration.
Mainely,Bob
Re: Amazing!
eaglesc
>An audience wider than Wood Central/ the internet?
That's pretty funny, you've got to be kidding!
