Re: DC and the lathe question?
Fog Tanner
>Barry, I have a dust collection setup, which I described in your other post. It works for me in capturing most of the dust, its intended purpose, and some shavings. But the larger shavings are going to fly. It would take an extrenly large amount of airflow to capture the shavings, something like one of those large floor fans behind your lathe pointing away from you. And that wouldn't get everything.
I had thought about the curtin you described for the same reason, but living close to the Texas coast where we have three days of brutal winter where it drops into the 70's or sometimes worse into the 60's, I have a fan on most of the time (except those three days). This precludes a curtin "box" in our area. But, it doesn direct the shavings into a given direction - more or less. There are some turners in our club who use a curtin as a wall to stop the shavings, and this seems to work well in thier shops. One member uses the old roll down window shades, but I have heard of shower curtin or just a sheet of plastic.
The other problem with a "box" around your turning area is the concentration of dust that you would be feeding your lungs or respirator. Either of which will just get clogged up quicker. And when turning bowls, you are going to generate dust when cutting and scraping. You can see this if you have a contrasting back drop. I see it going into my black dust collector "funnel". So, its not just when sanding that you will be filling the air with fine particles.
One of the things I did when I ran the metal ducting fro my DC, was to add a floor sweep next to the lathe. I keep a broom by it and when the shavings get too deep, I sweep them into the floor sweep. The bin on my cyclone is a 55 gallon drum, which I mounted on a dolly so it is easy to unhook and roll around and empty. I found that I would keep the floor clean more often when I made it more convenient.
Fog
