Moisture Meters: To pin or, not to pin!
Doug Reynolds in Seattle
>If I wanted to get a moisture meter to check on the moisture content of rough turned green bowls which should I get, one with pins or one without pins?
Would your answer differ if I wanted to check moisture content of supposedly dry lumber (boards) instead of bowls?
Re: Moisture Meters: To pin or, not to pin!
JKJ in East TN
>Doug,
Try the search - there was a recent discussion about moisture meters. I use a pinless. It was more expensive but doesn't leave holes in the wood. The ultimate tool junkie would have both.
Peter Toch
>I guess I'll have to admit to being an "ultimate tool junky", I have both pin and pinless types of moisture meters.
Pinless moisture meters work best on smooth, flat surfaces like milled lumber, but are very inaccuate on rough and/or curved surfaces like roughed out bowl blanks.
If you are determined to use a moisture meter on bowl blanks you are virtually forced into using a pin type meter due to the nature of the beasts you trying to measure. The upside is that you will get accurate readings, but the downside is definetly the holes that are left behind, especially after numerous readings over time.
Let me make a suggestion of how to track moisture loss from a roughed out bowl blank...by weight. There is no downside to this method and it will definetely tell you when the bowl blank is dry. As soon as you finish roughing out a bowl, number it with a pencil and on a sheet of paper write down the same number so you keep them paired. Then weigh the blank on a scale and record the date and the weight on the corresponding sheet of paper. Set the bowl aside to dry and after a couple of weeks reweigh it and record the date and weight. Repeat this weighing/recording process every couple of weeks until you notice very little to no loss from the previous weighing. At this point the roughed out blank is dry and at equilibrium with the ambient air. This does not tell you the absoute moisture content in percent, but it is a very accurate way to determine when the bowl blank is dry and ready to be turned to its final shape. And look Ma, NO HOLES! You also saved the price of a moisture meter.
Hope this is of help to you. Peter Toch
kevinT in T Bay
>The ones without the pin can be tempermental...i.e. faults reading if the Btteries are low, or if the back of the unit is not fully in contact with the back, How you hold the unit can throw off the readings.. But worht every penny. Cheers KevinT in T Bay
>I have both meters also. I use the pinless one in my work (home Inspections) and the pin one on lumber. You are right about the bowls. Neither is very good and the scales are better. I have a digital postage scale that weighs up to five pounds and cost about $30. Got it at a big box office supply store. Much better for bowls. Since I got a bigger lathe I think I need bigger scales, up to ten or twenty pounds, but you usually lose some of the accuracy. I have another set that weigh up to four hundred pounds, but they weigh in half pound increments, not close enough for bowls.
