Reversing a Jet 1236 ?
Pete in Holland, MI
>Anybody ever attempted or had success reversing the motor on a Jet 1236? Would only use it for slight reverse sanding at the end of a sanding project. I realize I'll have to create a flat on the threaded spindle of the lathe to set screw my chuck in place.
Thoughts ?
Re: Reversing a Jet 1236 ?
>Pete,
Given the Reeves drive, you're gonna have to either a jack shaft or some really serious rewiring of that motor (or both). Doubt it's goning to be worth you time to do it. If all you want it for is sanding, it'll be way easier to fashion an adapter for your chuck to mount on the outboard end of the spindle.
Mark
What Mark said +
Gerry in Maryland
>You may find it easier to just go around to the other side of your lathe.. Cheaper too!
Good Luck,
Gerry
Scott C
>I�ve done some research into reversing my Jet 1442. You can reverse any single phase capacitor start motor by reversing the connections of the start winding. This can be done with a simple DPDT switch. If you have access to those connections. Most fully enclosed motors like the 1442�s don�t provide that access.
A really simple solution if you can�t reverse the start winding is to wire a switch in series with the start capacitor. With the switch open, the motor won�t start until you give it a little push in the direction you want. Just don�t leave it stalled for more than a second or so as you�re drawing a lot of current with it stopped.
On the 1442�s motor, there are two capacitors. The larger one is the start and the smaller is the run capacitor. This type of motor is referred to as capacitor-start/capacitor-run. The purpose of the run capacitor is to improve the power factor and thus the efficiency of the motor. Again, reversing the start/run winding will reverse the motor. Alternatively, both capacitors can be disconnected for hand start. This will result in about 50% more current draw at low load, but still less 1/2 that of full load. This is what I�m doing with my 1442. I switch out the caps when I want to run in reverse.
The best way, from an electrical perspective, to reverse any single phase motor is to reverse the start winding. Another trick that works quite well is to replace the capacitor(s) with appropriate inductor(s). The phase shift of an inductor is opposite that of a capacitor and the motor will run in reverse. Finding the correct value for the inductor(s) is a tricky process. I�ve done this on my 1442 with the start cap (run cap disconnected) and it works great. It�s just bulky and simply switching out the caps works good enough for me. Now if I could only slow it down below 450rpm.
Good luck and be safe,
---Scott.
JimQ
>There also may be problems with the reeves drive if spun in reverse.
JimQ
