Kiln Space/rental *LINK*
Devo
>Hey All,
I know of a few guys across the nation that use a kiln to dry their roughed out bowls, etc. 1/2 of the bowls I work with are of the 12-19" range and anywhere from 1 to 2 inches thick in places. That being said, it takes some of this stuff YEARS to dry. My shop space is a little limited and with cranking out and average of 10 of these guys a week, and with a years dwell time (even with Alcohol), I'm running out of space FAST.
Has anyone ever heard of people selling kiln space/time? Know of any resources in Ohio, Indiana, Kentucky of PA? OR, am I asking for trouble in attempting to hurry the drying process. I'd like to be able to get to dry stable wood in about 6 months. 3 months to air dry, then however long a kiln takes.
Also, got the 1st cut of a website done. Still spell checking so, pardon the errors :)
www.devonpalmer.com
Re: Kiln Space/rental *LINK*
JKJ in East TN
>Devon,
I've been researching kilns and kiln drying. Most sources say air drying followed by kiln drying is the best way to go.
I haven't found one that will take small jobs - from what I've read I suspect this is because the drying schedule must be tailored to the specific load taking into account factors such as the starting moisture content, thickness, and type of wood. If you mix in roughed bowls with a kiln load, the bowls are not likely to be dried properly.
Have you considered making your own small kiln? There is much information available. A solar kiln is basically free to operate although it will probably take longer to dry, otherwise you could heat with something like electric baseboard heaters. The temperatures needed are not high - from 80F to 150F seems to be the common range. Another type of small kiln is a dehumidifier kiln based on a household dehumidifier.
Since you must measure and control both the temperature and humidity over the drying cycle, it is important that the kiln be well insulated and built with a good moisture barrier. You might make a small kiln from an old chest freezer or build a small well-insulated stud wall shed outside or in a basement or garage.
As for the drying times, William W Rice in Spring 77 FWW gives some sample times (from green): White pine: 8-9 days for 4/4, 25-30 days for 8/4; Red Oak: 21-28 days for 4/4, 56-72 days for 8/4.
Hoadley's book "Understanding Wood" is good, as is Taunton's FWW publication "Wood and How to Dry It", available from Amazon and elsewhere. Others: "The Conversion and Seasoning of Wood" by W.H. Brown, and "Harvesting Urban Timber" S Sherrill (I don't have this one but it was recommended to me).
I hope to build a solar kiln for lumber sometime in the next year and a second small dehumidifier kiln for bowls, blanks, and turning squares. I still have a lot to learn.
>John,
Haven't you plugged in the lab oven yet?
JKJ in East TN
No, it's in storage, waiting for the new shop. (As is the tablesaw, jointer, drum sander, etc, etc.)
Gary Evans Tallassee, TN
>Hi John,
I have Sherrill's book that you can borrow if you like.
I also have a solar kiln that needs to be taken down and transported to another location. Perhaps we can talk. 8^]
Gary
JKJ in East TN
Thanks for the offer. After writing that yesterday I hit up Amazon for that book and several others I've been wanting to read. I'm going to run out of shelf space soon. (Hi, my name is John and I'm a bookaholic.)
I'd like to hear more about he solar kiln. Send an email when you get time.
BTW, I pulled the bark off that other figured maple log and as you said, it appears to be nicely spalted. If the spalting carries through the figuring perhaps it is spectactular inside. I don't want to wait any longer so I might hit it with the chain saw this evening.
Brent Lehner
>In another part of the website "Russ's Corner" there is an article titled "Dryer for Turned Wood". He gives a pretty detailed version of building your own dryer out of a old dishwasher. Don't know if this helps, but I saw the article earlier today.
