Veritas - Innovation in Tools
bowl gouge
bowl gouge
bowl gouge
Pat
>What is the preferred grind, profile, for a bowl gouge?
Re: bowl gouge
How High is UP?
>You have opened a can or worms. There are about as many answers as there are turners. I have a 5/8" round bottomed fluted gouge with an Ellsworth grind on it and I like it and use it for nearly everything. (The rod it is made of is 5/8", but the flute is 1/2", so it may be sold as a 1/2".) I use it for bowls, roughing, even turning icicles for ornaments. I find it very versatile. It is my favorite tool. I have the jig for sharpening it and I can touch it up and be back to the lathe in seconds and the profile is completely reproducible.
I have no opinion on the profiles the others will mention because I got this far and quit looking. If you can, try out a number of tools. Join a turning club and borrow some or go to fellow members' shops and use theirs. Take a class at a Woodcraft store and use it as an opportunity to play with all he tools. Most turners have ten or twenty or even fifty tools, but but use five or maybe ten. Probably five on a regular basis. If you knew which five you were actually going to use, you could save a lot of money. Owning fifty tools is not a substitute for being proficient with ten of them.
Re: bowl gouge
Brad Vietje
Well put, Barry
Brad Vietje
>For beginners, I think the tried and true answer is to find a local AAW affiliate, and ask the same sort of question where you can get some one-on-one help, and maybe even a chance to try a few different grinds hands-on. You'll always meet some wonderful and helpful people, and probably meet a turning mentor or two.
Safe Spinning,
Brad Vietje
Thetford, VT
Re: bowl gouge
Brad Vietje
One more response
Brad Vietje
>OK, forgot to mention: It depends on what you want to do with it.
You might favor one grind for thin-stem natural-edge goblets, another for hogging out larger bowls, etc... Most bowl turners I know have one with a shorter bevel for working inside deep bowls, and a longer bevel grind for general use. Some do everything with one size, and one grind. UP is the limit...
Safe Spinning,
Brad Vietje
Thetford, VT
Re: bowl gouge
Re: One more response
Paul in Phoenix, AZ
>I have gouges with different grinds on each. The grinds I use the most are the finger nail and side grind (i.e. Irish, Elsworth, etc.) It's all in what you get used to.
Re: bowl gouge
Pat
>Your right, it was kinda an open question. I took a class a couple of years ago at a local Woodcraft store, it was a one night class on bowl turning, I bought a bowl gouge that night and the instructor put a different grind on it. I want to start off making some simple bowls and progress from there.
Re: bowl gouge
Pick One *LINK*
Randy Miller
>As has already been pointed out, there are so many variations and personal preferences be careful what you ask ;-)
There are quite a few already outlined in the grinds library -- I've attempted to add the link below, but if I messed up, just look in the Odds 'n' Ends section of the left navigation bar you'll see the title Tool Grinds Library.
Good turning,
Randy
http://www.woodcentral.com/newforum/grinds.shtml
