We value your privacy.
Any opinions on the lamp auger from Packard? *LINK*
Michael Recchione
>I know there was a thread on lamp augers a couple of days ago, but it's scrolled off the bottom of the screen now. Based on comments in that thread I was ready to buy the Clico from Craft Supplies only to learn it's out of stock at the moment. I was looking at several alternatives, and Packard seemed like a good bet because they also carry some other stuff I wanted to get.
Has anyone had any experience with this particular lamp auger? Does it drill straight?
>Micheal I looked in all my catalogs and could only find a lamp auger in Packard. I'm pretty sure I bought mine from Woodcraft and at the time they had 5/16 and 3/8. I bought the 3/8". I think they would all work good as long as you feed slowly and clear the chips. I've looked at the Gun Drills and would love to try one but they are a little expensive and the the lamp auger seems to work fine for my use.
Re: Any opinions on the lamp auger from Packard? *LINK*
>I think different places call different things the same thing and the same thing different things, if that makes any sense at all :-)
Both Craft Supplies and Packard call the thing they sell a lamp auger, but they're different. The Clico product they sell at Craft Supplies (at least from looking at the picture) is a traditional shell auger. The one they sell at Packard looks like a shell auger tip with spiral flutes to help clear the waste more easily. That sounds like a good thing, except I was a little concerned that the spiral design would be less rigid and might tend to wander. Maybe I just worry too much.
I have a feeling I should just pull the trigger and get started, and end the analysis paralysis.
>They are all quite flexible and will follow the grain easily if you push it in. I try to feed it carefully letting the drill do the cutting. I don't think the spiral back will change how it cuts, only how well it clears chips and clearing the chips often seems to help it run true. I would think the spiral might mean you could clear the chips less often. Don't know for sure.
Slight High Jack, Do these things really self cent
>The only lamp I ever tried to drill I drilled out the side. That was forty years ago in high school shop. I used an "end grain" bit on a drill press after I turned a lamp. My pride is still wounded. Time to get over it and make more lamps.
Do the ones that drill through the tail stock really self center? You would have to have a "hollow" tail stock. Does that come as part of the package with the auger? What about the drive center? Is it hollow or do you stop short? Can you drill from both ends? Is a No. 2 Morse taper big enough?
>Barry I'll try to remember all your questions because I didn't copy them. It is somewhat self centering. It's like a drill bit with only one edge cutting. In theory this would make it self centering. It does sort of but if you push it in hard it will sometime follow the grain a little off center. Still they stay centered way better than a regular drill bit.
A 3/8" auger will fit through a #2 morse taper but it depends on the center you use. I bought a #2 dead hollow center to be used with the auger. I didn't like the way it burns the wood even with slow speeds and wax on it. It turns out the Nova live center that I have has removeable points and they are a short #2 morse taper so I simply inserted the dead center in my live center. You can buy a live center especially for lamp auger from Peter child in England. I'd have to do a search to find that one for you.
Can you drill from both ends. You sure can and this is a good way to work around wood with really squirly grain. Drill half way through from both ends.
Did I mention you don't need a hollow live center if you have a hollow drive center. You can bore from the headstock side as well. Most of us don't have a hollow drive center. I did that once when I had a lamp mounted on a faceplate. I just bored the hole from the headstock side.
The one downside of drilling on the lathe is the thickness of the headstock or tailstock. This takes up a lot of the length of drill bit.
None of my centers are hollow. I will have to look into that. I have a drive center I don't use. Wonder if I could drill through it? Hmm, how hard would that metal be?
I had not really thought about the "length" of the head stock and tail stock. I guess that explains why the lamp augers I've seen are so long.
I have a bit that is very pointed and about eighteen inches long. It has two flutes and I believe it was designed to drill end grain. Are you suggesting that because it has two flutes it will have less tendency to self center? Now that you mention the length of the HS and TS, it may not matter.
>One article I read described making a large diameter hollow tailstock from a piece of pipe. This was for drilling large holes, not for lamp cord, but to make musical instruments.
Isn't a steady rest and a chuck another way to go?
Michael Recchione
>I have a hollow center, but another way to go might be to chuck the work in a scroll chuck on the drive side and support the other end with a steady rest. You could drill a not-too-deep pilot hole using a jacobs chuck in the tail stock, then remove the tail stock altogether and use the lamp auger to drill most of the way through, then flip the work around and go through the same routine on the other side.
Of course, I've never tried this, so I have no idea if it would work :-)
