Alchohol Question
Alchohol Question
Alchohol Question
Spence in Rhode Island
>I just picked up a couple of gallons of 99% isopropanol alchohol for a great price... Free! Any reason why I can't mix it with DNA? I'm not worried about the smell as its kept out in the barn. Just want to make sure that there is no dangerous reaction from mixing them.
TIA
Spence
Re: Alchohol Question
>You could mix it with DNA without any problem. The two types of alcohol are totally miscible (they mix evenly and completely). Then again, why bother? If you have a couple of gallons of isopropyl, they will work quite nicely. I have been using waste isopropyl from work (it's free and only contaminated with a little bit of polyethylene waxes) and works reasonably well. It just takes a little bit longer to evaporate.
>Thanks JL, I was just going to pour it into the barrel I use for soaking the bowls and stuff. Is there a big difference in the evaporation rate? As usual I'm in a rush to get some bowls ready for sale and if the iso is going to take a lot of extra time I'll hold off on using it.
Thanks again
Spence
>I am afraid I wasn't clear enough. Yes, isopropyl alcohol evaporates more slowly. But not slowly enough to make that much of a difference. For example the vapor pressure of ethyl alcohol is 40 mm Hg at 19 C and the vapor pressure of isopropyl alcohol is 35 mm Hg at 20 C. This means that ethyl alcohol will go into a vapor state slightly more easily - but not that much. You can mix the two alcohols and the difference in evaporation rate would be a few hours (not days). You are safe in mixing them.
>Thanks again JL. mixed them and a maple bowk is soaking as we speak.
