Trend Airshield battery problem
JimQ
>Anybody with the problem with Airshield batteries not staying plugged into the charger; Contact Terry Cole with Trend-USA at 270-872-4674. Just leave him a message and he will call you back. I just talked to him on the phone again today. They had a problem with a new battery supplier when they shifted from Ni-Cad's to NiMH. A lot of defective battery packs may still be out there, and they are trying to make good on them. Replacement cost will depend on how long you have had the Airshield. If it is fairly new....Free, like mine.
JimQ
Re: Trend Airshield battery problem
Re: Trend Airshield battery problem *LINK*
Chas
>Thanks for the heads up on that, I have had similar problems.
UK Workshop Thread on same battery problem.
Carole in VA
>The replacement ones they sent me were worse than the original ones, plus they were larger and didn't fit into the battery compartment unless you took the foam out of the end. One of the connectors was actually loose in the battery and that one won't charge at all. I gave up after getting no response to my email and just use the old ones. They will stay plugged in if I don't move them around too much. Don't know why they don't put a darn light on the charger so you know when proper contact is made and when the battery is charged.
Chas
>Carol, the UK charger has a LED indicator showing when current is flowing but still no charge time limiter.
