Barbara Gill: A couple of Velvit oil Q's
Gary Evans Tallassee, TN
>Hi Barb,
I turned a little cherry box and have put a couple of coats of Velvit Oil on about an hour apart.
Questions:
How long do you normally wait between coats?
Have you ever put a topcoat of Poly over the Velvit Oil?
How long would you let it cure before using the Poly?
Thanks,
Gary
Re: Barbara Gill: A couple of Velvit oil Q's
Barbara Gill, Remlik VA
I usually apply the first coat until it no longer soaks into the wood and then wipe off after it just starts getting thick. I wait at least 8 hours before applying a second coat. It depends upon the temp. and how much oil the wood soaked up.
For instance, I just finished turning a maple plate which must have been a little soft as the wood soaked up about 1/2 pt of oil. I will let that item dry much longer than if just a little oil had been used.
No, I don't like to use poly. If you use several coats of oil, let cure and buff you will get a wonderful glow to the wood.
You can use poly over the oil after it is completely cured. Here again cure time will depend upon temp, etc. I always believe in erring on the side of caution. If I was going to apply poly after the oil I would bring the item home (my shop has no heat) for at least several days but more likely a week before applying poly.
>Thanks, Barb.
I was hoping it might cure a little faster. I'm supposed to deliver this box tomorrow night for an 18th birthday present. I may have to take a little oil along with it and let the birthday girl do the finish coats. I think she would enjoy it.
Gary
>Gary, since the wood is cherry which does not usually soak up much oil, the finish you will have will be ok but not as nice as several coats and then buffing.
gary clarke
>what is velvit oil? I googled it and could not get a straight answer as to what it is, tung oil? linseed oil? whatever?
>I am not able to give you all the ingredients. It is a soy oil base with mineral spirits as the carrier. There is no Tung Oil in it.
