Masur Birch
Masur Birch
Masur Birch
Michael Stafford
>I have a friend who travels a lot for business. During these travels he looks for wood for me to add to my collection of exotic woods that I have made woodturning/working projects out of. On a recent trip he brought me a small log in the round of Masur birch. This log is about 12" long and 7 1/2" in diameter. It is sealed with wax and wrapped securely in multiple layers of plastic. Obviously green... My question is how do I go about cutting this up into usable pieces for turned end grain boxes? What should I do as I cut this up? What pitfalls should I be looking to avoid? I have never worked with this material before so I do not want to mess it up if at all possible. Any help, advice would be appreciated.
Re: Masur Birch
Keith Tompkins
Re: Masur Birch
Keith Tompkins
>HI Michael, I have turned this stuff....it's fairly hard material, but turns nicely. For end grain boxes, rough turn it oversize and allow to dry, then turn to final size. Same idea for end grain vessels, either turn in one shot and allow to warp, or turn a bit heavy, and allow to dry, then return. A paper bag will help stabilize the drying process. Many here use the alcohol method, I haven't, so cannot help there.
The figure in the wood is outstanding....reminds me of flames.
Re: Masur Birch
Re: Masur Birch
Michael Stafford
>Thank you for the response. I also use the alcohol method and anticipated using it on this as well. Just wondered if there were any hidden problems with the material that were not obvious. Hopefully I will turn it successfully. One piece of advice I received was to turn it pith centered if I chose to turn it end grain as in a vase or bowl orientation. Sound reasonable?
Re: Masur Birch
Keith Tompkins
Re: Masur Birch
Keith Tompkins
>Hi Michael, all of my goblets are turned with the pith off-center for strength, no problems with that at all. I am not sure about end grain vessels.
Re: Masur Birch
Brad Vietje
Re: Masur Birch
Brad Vietje
>Michael,
Turning an end-grain vase or bowl can be chancy if centered on the pith -- it will have to be pretty thin, and even in thickness to avoid cracks. I do it all the time, but I'm very careful to turn it to final thickness when green, and make sure the foot (with the pith down the center) is the same thickness as the rest. This usually means reversing the piece to hollow the foot somewhat. you can then re-mount after drying for sanding and finishing -- if turned on the pith, it won't usually go much out of round.
For end-grain boxes, you can quarter the log, then rough-out boxes from the four quadrants, leaving them about twice as thick as final thickness, and drying them slowly (paper bags, etc...) or the ethanol method, before re-turning to finished size and fit.
Depending on the desired dimensions, you could either make 12 boxes (each blank about 4" tall), or maybe cut the log roughly in half, and make 8 boxes and a full-diameter bowl, vase, or hollow form centered on the pith (or two bowls in side-grain orientation). I'd personally choose 8 small boxes and one fantabulous hollow form !
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Masur Birch
Re: Masur Birch
Michael Stafford
>Thank you guys. I like the advice. I have a friend who does hollow forms so I will give him a piece and I will "box" the rest.
Re: Masur Birch
Re: Masur Birch
MFoster
>I have had the pleasure of turning several nice pieces from Massur Birch. I obtained a log about 6-8 in in diam by 4 ft. My log also came sealed with wax, but I found it was relatively dry to start and showed no checking. I decided to gamble and turned a bowl centered on the end grain. To my surprise I had no checking and minimal distortion. I wound up getting several closed and open form hollow forms out of it. They were all centered on the pith, with the pith left intact. None checked or split. They all were turned pretty thin (about 1/8 "). I turned them all as natural edge with the bark intact because they looked so nice and sold very well. I have been looking for a similar log, but haven't found one yet. I have pics of a couple of them on my sadly ignored (I have not updated it for a couple of years now ) website at http://www.vermontel.net/~mfoster/index.html Follow the 2002 link and scroll about 1/2 way down.
