We value your privacy.
>None of the above. Cut through the pith of both forks at the same time. That would be at right angle to option 2. The best figure will be below the fork.
>I just cut and turned a number of maple crotches.
If you cut through the pith, you can see the feathering very well and get the best placement of your blank. You also will be able to make two blanks, one from either half.
I've never seen this discussed, but one thing to consider: the very best figure is often right down the center plane through the piths. You lose some of this from the beginning from the wide chain saw cut, and you will cut away even more with any waste you turn away at the bottom (foot, tenon, etc). And unless the bottom is turned very thin, the inside of the bottom of the bowl may be just above the best figure that remains.
If you open the crotch just to one side of the pith (allowing for mounting tenon, foot, bottom thickness, and waste) you might be able to get the most spectacular figure to show up right at the inside of the bottom of the bowl or platter. However, this method will give you only one feathered blank instead of two.
