Lamp Augers
Lamp Augers
Lamp Augers
Greg H. of WI
>I'm looking at lamp augers, Craft Supplies has a clam shell I believe from Clico and Packard has a Hamlet traditional? Good or bad, any tips out there?
thanks
Greg
Re: Lamp Augers
Re: Lamp Augers
phil in NJ
>I got the clico from craft supplies. no issues, it does what is intended.
I am a bit concerned that there is very little material to allow future sharpening, that's my only issue with it. But that seems to be true of most lamp augers.
Re: Lamp Augers
Does it drill straight ? ,
Fred in NC
Re: Lamp Augers
Re: Lamp Augers
>Greg I bought the one from Woodcraft. It did OK right out of the box but I was trying to drill very long holes and found that I had to sharpen it much keener than it came. I've used it a lot for lamps 15" and under with great success. I jury rigged a special live center for my tailstock. I have a Nova live center with removeable tips. They are a very short #2 morse taper. I bought the hollow non live center from Woodcraft or Craft Supplies. It has a #2 morse taper and fits very nicely in my Nova center. I also drilled a hole all the way through the side to help clear the chips.
Re: Lamp Augers
Re: Does it drill straight ? ,
>Fred I did a lot of testing of different drills and such when I needed to bore a hole through a 4 foot piece of hardwood. After many trials and several diffent bits including homemade, the 3/8" auger I got from woodcraft did the best. There is some technique involved. Sharpen it as sharp as you can get it. Use as little pressure as possible. The more you push the more it want's to follow the grain. REtract and clear the chips really often. This may be more important than how little you push. Even then when drilling a 3/8" hole from each end of the workpiece you will end up with a hole that is slightly offcenter in the middle but will let a lamp wire go through. Some woods are worst than others about making the drill bit wander. I always drill the hole first and then mount the wood between centers in the holes so they will be centered. This way even if the drill bit wanders your holes will still be centered.
Re: Lamp Augers
Re: Thought about a gun drill??? *LINK*
Danny Wells
>Greg,
At the Texas Turn or Two, there was a demonstration of using gundrilling for drilling the holes for bagpipes. This is really cool. Gun drills have a flute, similar to a gouge, and an air tube drilled all the way to the cutting edge. When drilling metal this tube is used to introduce oil. By introducing air at the cutting edge, all the shavings are blown down the flute and out. He could drill a 12 to 15 inch hole in less than a minute, and it was straight.
Gun drills come in all sizes and lengths. So far the prices I've seen are about twice that of a lamp auger, but if you're going to do a lot of lamp holes, the time and aggravation saved might be worth it. Here's website to look at. If this is interesting, let me know and I'll send you some more info.
Gun Drills
Re: Lamp Augers
Phil in NJ
>The clico drilled straight enough to meet dead-on in the center of a 24" lamp, going through the tailstock only (reversing the work halfway through).
Re: Lamp Augers
What size did you get?
mike recchione
