We value your privacy.
>I am wondering how sucessful the use of alcohol drying of rough turned bowls has been for folks. I have already read the Dave Smith article on the subject and looked at older messages online. Seems like a great idea and I have invested in alcohol and soaked a few bowl blanks, so I may have my own answer in a couple of weeks, but I would still like to know how well folks feel it works. Most turners I have talked with in my area, have not heard of it or are experimenting with liquid detergent. Thanks, Ron
>Ron, I can honestly say I have dried over 75 (probably many more now that I think about it) roughed out bowls using Dave Smith's Alcohol Method, and to date, I have only lost one bowl. The failure was more my fault than the method itself. I left the walls too thick on an Osage Orange Bowl, and it had some pretty deep cracks. I probably could have saved it if I wanted to try, but I just roughed another from the same tree, thinned the walls, and it dried like a champ! I have used this method on Ash, Cherry, Bradford Pear, Walnut, Elm, Apple, Crabapple, Osage, Maple, Sassafras, Mulberry, and Plum. (I am sure I missed a few, but you get the idea!) Trust me, it works.........and it works really well. I follow Dave's instruction to the letter, especially the wrapping of the soaked bowls. I wrap them as soon as they come out of the bath, when the Alcohol has flashed off. I soak mine for 24 hours.......not that it is necessary, but it works well that way for me. I dry for 2 weeks wrapped, then for a minimum of another week unwrapped. Just make sure you handle the wet bowls with rubber gloves.........just to be on the safe side, to eliminate any skin absorbtion.
>I've also had great luck with the method. I soak my bowl blanks (and other small pieces) overnight, then wrap them in brown paper and store them in a rack in my basement. After about 2 weeks, they're around 12% moisture content, as measured with my moisture meter. They seem to stabilize around 10-12% from then on. If you want the moisture content to be lower than 10%, I find that 30 seconds to 1 minute (depending on size) in a microwave will lower the moisture content to 6-8%. After nuking, I let them stabilize again for a couple of days, and they're ready to go.
>Ron, while nothing is the perfect answer to perfect "quick" drying, the alcohol seems to be doing the trick for quite a few turners. I have tried many different methods including, the liquid detergent, boiling, microwaving etc. and seem to have settled in with the alcohol. I get the most consistent results. Every now and then though I get one that just will not cooperate. I had one the other day that after the alcohol dunk...went so completely out of whack and cracked so bad that there's no way I can even get it back on the lathe. It's just fried. Right now I can't think of what wood it was either? I'll have to ask Kurt Krauter....he gave it to me. It was some funky wood I'd never heard of. Anyway....I hope you're as happy with the alcohol soaking as I am. I just finished turned 3 sycamore bowls that were standing as a tree just 2 weeks ago. They came out fantastic. Could not have asked for better results...in such a short period of time.
I have been very successful using this method. I currently have over 100 bowls ready to be finished all roughed and dryed this year. I have lost a couple of cherry pieces but I believe there was a flaw in the wood.
>One helpful hint, if I may. Get a container that seals tightly and store the DNA outside. I was given a 5 gal container that has a rubber seal and the lid snaps tight. Works great and saves money. Phil
>Thanks to all of you who responded. The alcohol soak method obviously works very well. In fact, it appears to have an almost 100 percent success rate! That is fantastic. It is now in my bag of tricks for wood I want to dry fast. I also want to say a word of thanks to Dave Smith who originally did the research and posted the idea. It was obviously a lot of work. Ron
