Tapping Acrylic for Bottle Stoppers
Jonathan Spool
>I have just ordered a batch of the gold titanium bottle stoppers from Berea. I plan to turn the tops from acrylic rather than wood.
Rather than over size the hole for the mandrel to thread into, which gives rather little depth for the threads, I would like to drill the hole and hand tap with a bottom tap. Unfortunately the threads of the stoppers are 6mm x 1.5. I can find plenty of sources for taps that are 6mm x 1, but not with the 1.5 thread pitch.
Does anyone know of a source for purchasing a 6mm x 1.5 tap? So far I can only find companies that can have one made for me for around $80!
Any help would be appreciated.
Jonathan
Re: Tapping Acrylic for Bottle Stoppers
Pete in Holland, MI
>You sure about 6 x 1.5? That thread doesn't show up in any of my machine tool supply catalogs, nor Machinery's Handbook.
Rick Allen
>Aren't those 3/8" NC threads? And forget the bottom tap, just drill the hole a little deep and use a regular tap. The one I got, cost less than $5, if I recall correctly.
Good luck
Re: Tapping Acrylic for Bottle Stoppers *LINK*
Ed Davidson (Colorado Springs)
>Jonathan,
There are two Berea stopper base configurations available...a cone shape and one they call the "All Chrome" that is kinda oddly shaped and very heavy. The thread pattern is different on each.
The cone shaped stopper has a 3/8" x 16tpi design. There's a link below for the cone-stopper base tap.
The �All Chrome� version uses a smaller threaded rod, and requires a 6mm or 15/64� hole. I don�t know exactly what tap would be appropriate for it but if this is the stopper base you purchased, you might try a 1/4� x 32tpi tap.
Did you purchase one of the treaded mandrels that are used to mount/turn these stoppers?
Best regards,
Ed D.
http://arizonasilhouette.com/ProductCart/pc/viewPrd.asp?idproduct=584
Jonathan Spool
>Hi Ed,
I did purchase the mandrel for the "oddly shaped, heavy" all chrome bottle stoppers. Although I have not recieved it yet, I was told that they do have the 6mm threaded piece. I did not think of cross referencing the metric with standard.
For those who posted a response regarding the 3/8 thread, that is only for the more common pointed cone type bottle stoppers.
As there has been some discussion as to what the actual thread is, I will probably wait until I have the mandrel in hand, prior to making any purchases.
Thanks
Jonathan
>Jonathan,
The reason I was asking if you had purchased the mandrel is�if you can�t find the right tap, you might be able to use the mandrel itself to tap threads into these hard acrylic blanks�give it a try.
BTW, there's been a lot of discussion on the "All Chrome" stoppers in the past, especially about the odd shape. You might be interested in a little alternative design approach described in the link below.
Best regards,
Ed D.
Berea Stopper Turning Alternative
Jonathan Spool
>Thanks Ed,
You have been very helpful, and thanks for the link! Someone(John) sent me an email (not posted on WC)that they use a 6mm 1.25 tap and it works fine for them. John also sent me a link to page 35 of the Enco cataloge where they are available. They were inexpensive at $2.47 so I ordered a couple to give it a try.
The reason I started the thread was that I was told that in order to get the mandrel to thread into acrylic, I would have to drill a larger thread than I would in wood. The threads would not be as deep, and with my propensity to twist off dowels when roughing a stopper blank I had no doubt I could strip out that hole with little difficulty!
Thanks
Jonathan
Russ Fairfield
>Running a tap into an acrylic will be a little easier if you use a few drops of kerosene as a lubricant.
Al Goldstein
>Jonathan,
Standard taps are designed for metal and have four flutes and four cutting edges to cut the hard metal. The flutes are small because the metal shards are small.
Better to use a tap with three flutes. Acrylic is softer than metal and three cutting edges work well. The larger flutes handle the larger shards sheared off of the acrylic.
When I use a standard four flute tap in acrylic I have to periodically back out the tap to remove the shards stuck in the flutes. With a three flute tape I can just ram through the acrylic with one try.
Hope this helps.
Al
