We value your privacy.
I am making some spindles and a detail that I've made many times before does not want to come out today, starting vertically cut a cove to end horizontally, gentler near vertical and sharper near horizontal. It's been a while since I turned spindles and today I can't make the cove.
>Jorge It can be done with the skew but only if your really good with it. It also depends on the size of the skew. The width of the bevel on the skew determines how steep the cove can be unless you turn with the upper 1/3rd of the skew which is dangerous and requires a lot of control.
It's much easier to turn a cove with a spindle gouge. Even then starting the cove can be difficult. If you don't have the bevel exactly on the plane you want to go it will kick back on you. I teach 2 tricks to starting a cove. One is to start the cut with a parting tool. Just go down about 1/32 or so. Just enough to create a shoulder. The bevel of the spindle gouge is then placed against this shoulder and the cut proceeds. The second way to do this is to cut the small shoulder using the toe of the skew. This is cleaner than the parting tool but takes a little more skill.
Once you've started the cove cut with the flute facing either the headstock or the tailstock (depending on which side of the cove you are turning) you rotate the gouge so the flute is facing up at the bottom of the cove. Then cut the other side from top to bottom using the same sort of scooping action with the gouge.
>Hi Jorge, the easiest way to turn a cove: the tool to use is a detail gouge. Start with the tool on its side, the flute at 90 degrees to the tool rest. The very point of the cutting edge should contact the wood right at the center-line, the handle parallel to the bed of the lathe. With the bevel to the outside of the cove (flute facing in) just touch the turning with the tip of the cutting edge. Don't try to cut, just make a small line or groove. that gives the bevel something to ride against, and helps prevent the tool from threading away from the cut. Once the groove is formed, start the cut. Always large diameter to small!
As the tool approaches the center of the cove, roll the gouge over so the flute is facing up, at the same time slightly lower the handle to keep the bevel rubbing. For the other side of the cove, repeat the procedure from the other side .
A skew CAN be used to form a cove, but not easily!
The P&N detail gauge is the newest addition to my arsenal, just a couple weeks and after following your instructions in practice blanks I am sold, it works just fine, it also made me realize part of the problem is the stock I was using wich is not straight grain, so there is tear out in spots, I better find better stock and save a lot of trouble.
>Oooh I'm jealous. I've been wanting one of the P@N spindle gouges. I already have 5 spindle gouges of different size so it's hard to justify but after using one I really liked the heft and the shape of the flute.
>Aha! there it is. Yes, Jorge, that will work! I grind mine even further back, about an inch overall. That way, I can hollow boxes and goblets with the same tool.
I could not help it, skews are the only turning tool I see on the old tool joints around here and they used to be only a couple bucks apiece. They are all different sizes, only the 3/4" is repeated because somebody gave me one, and that is good because is the size I use the most. Did you ever turned with a 2" skew? Looks very impresive but is the easiest one to use.
