drying cocobolo
drying cocobolo
drying cocobolo
gary clarke
>I have some 3x3x24 cocobolo which has a 20% moisture content that I will make into pepper mills and wonder what is the best way to dry it? Guess it will have to wait for next yr for xmas.
Re: drying cocobolo
Re: drying cocobolo
JKJ in East TN
>How do you know it's 20%? The stuff I have is so dense it seems to trick my meter. (I haven't tried the oven drying method)
Even though it read high, I made some boxes with nice fitting lids. Two years later, I asked and was told the lids still fit.
Can you make your objects like you do a rough-turned bowl so it can dry from the inside as well as outside, then finish turn later?
Re: drying cocobolo
Re: drying cocobolo
gary clarke
>I used a moisture meter( wagner L609) and I wonder if the high oil content of cocobolo would cause a false meter reading. In the adjustment tables there is no listing for cocobolo. I guess I could make a small pepper mill( 6in) and see what the results are.
Re: drying cocobolo
Re: drying cocobolo
JKJ in East TN
>If you have time, how about trying a the oven test method? I used to work for a testing company and we even measured soil samples this way.
If you haven't done this before, start by measuring the wood with the meter as a reference then check the actual MC.
Cut a small chunk away from the end if you can. The usual recommendation I read is to use a strip 1" wide cut all the way through the board about 1' from the end of the board, but that would not make sense for a piece of cocobolo turning stock! I'd probably try to cut a piece about 1" x 1/2 or 3/4", assuming an accurate scale is available. (see below) I use a laboratory grade triple-beam balance.
Weigh the sample to get the "wet weight". Bake the wood at 225F for several hours. Weigh again to get the "dry weight". MC% = (wet weight - dry weight) / dry weight * 100
What I don't know is if the "several hours" recommended will work as well for a tropical wood as it will for our typical domestic woods. Cocobolo is so dense and resinous that I wonder if the moisture will take longer than "several hours" to escape even under heat. (Under a microscope what few pores exist are chock full of a hard resin that looks almost like amber.) Before weighing and drying, it might be best to split the piece up into smaller chunks that would dry faster. It won't help to increase the heat much or some of the weight may escape as smoke!
It would be great to know just how close or far off the meter was with cocobolo - I've wondered the same thing for a long time. I have the same meter, so if you can't get to it or don't have a scale, maybe I can try it this weekend.
BTW, for useful results, expert George Wengert recommends weighing to at least 0.5% of the sample weight - a 100 gram weight needs to be weighed to 1/2 gram.
Re: drying cocobolo
Re: drying cocobolo
gary clarke
>JKJ, sounds like a good method, however I do not have a scale that will measure that small weight.
Re: drying cocobolo
Re: drying cocobolo
Steve Mushinski
>Gary I will do a little testing later as I have some numbers for cocobolo but I have to find the sheets. I would think if you used a meter without any ajustment for the type of wood I might multiply your reading by .5 or less due to the the oil. So I would say your wood "might" be in around 10%.
