PM 3520 Vibration Problem Solved
George Van in WI
>Thanks to all that helped me with the vibration problem.
The problem was solved by replacing the bearings and removing the 3/8” bolts and leveling pads, letting the cast iron legs rest directly on the 4x4 trestle riser. I could not believe the difference when the pads were removed, 90% improvement.
Turning smoothly in Wisconsin!
George
