Mini-lathe base
Mini-lathe base
Mini-lathe base
Doug Reynolds in Seattle
>I am looking to make a base for my Jet mini-lathe to add ballast, height and a place to keep some tools and such. Found a short article on the Wood Magazine website that includes a materials list but only a picture of the finished product, no exploded drawing of the various parts. Do you know of actual magazine articles available? TIA, Doug
Re: Mini-lathe base
Re: Mini-lathe base
Jeff M
>Doug,
Check out the article "How to Build the Leady Lathe Stand" in WC Articles & Reviews/Turning Tools & Techniques.
Re: Mini-lathe base
Re: Mini-lathe base
JimQ
>Here is a picture of the bench I made. The top is a 6' length of 5X15" GluLam. This is the laminated lumber that is used for beams. I got mine from a waste pile at a large construction project. You can occasionally get cutoffs from prefab roof companies. The legs are 2X6 with the back legs skewed out about 15-20 degrees.
It has plenty of weight to help with the vibration from rough cut logs for natural edge bowls.
JimQ
