A55 Smoothing Plane
Delta 1440 HS questions
Ryan McMullen
>Hey all, I figured with the great knowledge here someone may be able to help me so I don't have to try to call the people at Delta.
I just picked up a Delta 1440 lathe this weekend. I knew that it had been well used and got it for $200, figured at that price I could afford to put some money in it if needed. Well it looks like I need to.
When I was cleaning it up I found part of a washer or retaining ring (don't know which one) in the HS area. I did notice that the handwheel side of the spindle has some play in it (which is why I think at high speeds there is a small amount of vibration). Now it does not appear to move the working side of the spindle when then handwheel is moved. I'm thinking that the broken washer/retaingin ring is allowing some play on the reeves pulley side of the HS assembly.
Here's my question. For about $50.00 in parts, I can get all new bearings, washers and retaining rings from Delta. Should I just go ahead and replace all these parts, or just try to find the missing part and replace it. I have no idea if there is damage already done due to the play from the missing part. Hopefully this week and can disassemble the HS spindle and find out what the broken part actually is.
Also I think this vibration has caused some excess wear on the belt so that will be replaced as well.
Thanks for any help.
Ryan
Re: Delta 1440 HS questions
JKJ in East TN
For that cost, I would not hesitate to replace the parts. That part of the lathe would then be like new.
I would dissassemble the headstock first to make sure there is nothing else wrong, for example, a piece of broken hardened washer can destroy shafts and seats. (My friend had to replace an entire expensive motor in his heating system when a setscrew came loose and did some machining on the motor shaft.)
Gerry in Maryland
>Ryan,
For what it's worth.. I'd look over the spindle reeves pully too.
I replaced it and all of the other parts that you have listed on the Delta that I had. It's a pain getting it all apart but if you do it all at the same time you won't have to repeat your efforts all over again in a few months time.
Just my $0.02
Gerry
Ryan McMullen
>Gerry,
So are you saying to replace the reeves drive pulleys or just the bearings?
I was planning on replacing that bearing as well, but Delta is currently back ordered on it. I will examine it carefully and if it does need to be replace then I will wait with reassembly until it is replaced.
Ryan
Ryan McMullen
>OK, one more question. When I get to reassembling everything. what whould I use for a lubricant? Especially for the reeves drive pulley.
Thanks
Ryan
Phil Joines Krum, Texas
>If you take the bearings to a good bearing shop they should be able to match them at a much better price and probably better quality too.
Gerry in Maryland
>Ryan,
I would look at the motor reeves pulley and check for wear at the keyway. It's a lot easier to remove and replace it on the motor first. If there is slop in the keyway I would suspect the same on the spindle reeves drive. I had problems with both of mine and it sure made a big difference when I replaced them. My bearings were ok but I replaced them too. Like Phil said, a good bearing shop will have them and they are not that expensive.
Gerry
Gerry in Maryland
>Ryan,
I used a dryfilm lubricant on the moving reeves parts. It's been awhile since I repaired mine but I think it was a DOW product.
Gerry
Ryan McMullen
>Just thought I'd post an update on my rebuidl saga. I have most of the bearings on order, I'm haveing a hard time finding one of them. I have the HS completely taken apart (OK, one bearing is still on the spindle, but I'm working on it :) )
Here's what I've found. I found where the one borken/worn through retaining clip went. Found one bearing is damaged, but I don't think that it is the source of the vibration. The damage appears to be part of the seal is depressed or indented. The bearing still turns smoothly and no woble. What I did find that is of concern is that the ID of the bearing is supposed to be 25mm, and the old one is. But the location on the spindle shaft where that bearing goes is only 24mm. I guess is seems at one point the bearing may have seized and the spindle wore down a bit??
I'm going to try to call Delta today to see if I need a new spindle, I may just order a new one anyway, that way the entire HS will be new.
Ryan
