We value your privacy.
>I got a set of Power Grip Jaws when I got my larger lathe in anticipation of trying some deeper hollowing projects. I have not used them yet. My question is should I always turn the tenon without a dovetail and long enough so it uses the entire depth of the jaws, including the serrated part? Is it OK to use the normal short dovetail tenon on lighter projects? Is there a rule of thumb for weight and length of workpiece where I should use one or the other (just dovetail or full grip)? The piece I want to work with right now is about 12" long and 8" square (and heavy). I hate to lose so much of it to a tenon that's the full depth of the jaws if I don't have to.
Is this the Technatool Supernova series? You should have a manual with a chart giving recommended maximum stock sizes for each set of jaws. I think they also include recommended spigot (tenon) sizes. According to them, the Technatool Powergrip jaws can handle an 8" diameter by 12" long workpiece.
You don't need to grip a long tenon fully into the jaws, but make sure the front surface seats tightly against at least a small a rim turned on the tenon or base. This helps a lot to keep the workpiece firmly aligned. I leave enough tenon depth so it "seems" strong enough to me. A big workpiece with a short cracked or punky tenon can be a disaster.
Also, you probably know this, but there is an optimum tenon diameter for each jaw set. For the best grip keep the tenon size just slightly bigger than the smallest diameter you get when closing the jaws fully. This will allow more of the circumference to grip the tenon instead of gripping only at the sharp corners of each jaw (8 points) where they will tend to crush fibers. This is weaker than gripping firmly all the way around. Of course, if it is green wood, you must make the tenon a little larger to allow for shrinkage if you plan on on rough turning now then finish turning later.
If used at the optimim size, the jaws can even grip a finished bowl foot without marring, although a bit of tape is good insurance.
>What he said. Carole, as you know, I have the same lathe and the same chuck and jaws. I save the full depth tenon for really heavy pieces, maybe fifty or sixty pounds and out of balance. Most of the time my tenons are about 3/8 or 1/2" long and I rely on the shoulder to do most of the work.
>I've only lost 2 or 3 pieces over the years from tenon problems. 2 of the 3 broke where the tenon goes into the bowl so no amount of extra length would have stopped that. The other one came out of the jaws so maybe the extra length would have helped but probably just stopping to tighten the jaws would have worked.
