Removing wax
Removing wax
Removing wax
Wayne Cease, Atlanta
>I have a maple burl that is sealed in wax. I need to remove the wax from the spikey burl cap. I want to leave that end the way it is, but without the wax. The other parts I can cut, sand or turn off, but not
the spikey part.
I did a quick search on the site, but didn't find post. Maybe I didn't go far enough back in time.
Thanks,
Wayne
Re: Removing wax
Re: Removing wax
Sean Troy
>Pressure wash at the car wash works well.
Re: Removing wax
Re: Removing wax
Brian Hahn in SW Wisconsin
>Try paint thinner / mineral spirits and scrub with an old tooth brush. Other solvents like lacquer thinner will work as well, but the fumes are more hazardous to breath.
Re: Removing wax
Re: Removing wax
Juergen
>Heat Gun, like one would use for paint stripping.
Re: Removing wax
Re: Removing wax
JimQ
>That can melt the wax right into the pores of the wood. Pressure wash warms it and blows it away at the same time.
Dish detergent, a brush, hot water, and elbow grease works too.
JimQ
Re: Removing wax
Re: Removing wax
Rick in Colgate, Wi
>We have one of those small steam cleaners that are used for cleaning showers and sinks in the home, that may work tho I never tried it to remove wax, will give it a try on anchorseal to see what it does.
Re: Removing wax
Re: Removing wax
JimQ
>Might help to spray on some detergent after the first pass and let is soak before doing a second pass. Also, watch what is beyond the spray pattern, you don't want to have to clean the whole side of your house.
JimQ
