REAL MILK PAINT
DC motor control for variable speed lathe
Phil in NJ
>Wondering what is required to hook up a DC motor for variable speed operation on a mini lathe...
I was thinking of a Vicmarc VL100, then adding a DC motor off ebay and whatever control unit is required.
What do people use to get variable DC supplies from 110v or 220v? I think 1/2 to 3/4 hp would be sufficient.
Thanks!
-Phil
Re: DC motor control for variable speed lathe
Brian Hahn in SW Wisconsin
>I'm not sure I understood the question, but the speed controller for a DC motor converts the AC line to DC for the motor. Just be sure get the correct voltage match. For example, my lathe motor is rated as 180 Volts DC and the controller is 220 V. This correlates with info I've seen elswhere using a 90 V DC motor with a 110 V controller.
Phil in NJ
>Sorry, I guess the question wasn't clear. :)
I have a source for a nice DC motor... but I don't know what to get to control it... some sort of variable DC power supply.
Anyone have a brand/model of a variable voltage DC powersupply for a 3/4hp motor?
Thanks
Phil
Bob Hash
>Try the following site. They are very helpful and will tell you what control you need for the motor you have. I bought a dc motor and control from them for my Vicmarc VL100.
http://www.surpluscenter.com/
Fred in NC
>I sencond that. Surplus Center has some real good controllers, and also some very low priced DC motors.
One thing to remember is that you don't have to match the voltage exactly. For example, you can run a 130 VDC motor with a 90 VDC controller. The result is a proportional reduction in the horsepower.
1 HP rated 130 VDC motor run at 90 VDC will give you about .69 HP.
(90/130 times rated HP). Thus you can buy a bargain treadmill motor and get plenty of power for your lathe.
Ed Moore
>Bob,
I have considered getting a VL100 and doing exactly what you described. Are you pleased with the result?
What size motor did you get?
How would you rate your VL100 compared to a Jet Mini?
Thanks,
Ed Moore
Bob Hash
>I am pleased with the Vicmarc. I bought a 90VDC 1/2 hp. motor.
If you go this route, the belt supplied with the lathe will be too short and need to be replaced.
