sharpening kelton hollowers
DWFII
>How does one sharpen the kelton hollowing tools. I've read, and followed, the instructions but my standard half round scraper is sharper (and cut better and with less vibration) inside the vase than the Kelton tools. I'll be forced to to buy a Sorby MultiTool if I can't improve the keltons. (my Hollowmaster works great but won't get deep enough into this vase.)
Thanks
DW
In the High Desert of Central Oregon
Re: sharpening kelton hollowers
DW, I use the diamond files
TDaniel
>a few upwards strokes with the purple or red files will do the trick. Just follow the original profile and raise a burr on the top edge.
Re: DW, I use the diamond files
DWFII
>TD,
Thanks fro the response. I tried that, my results were not very good. I think one of the problems is that having only the Jet "midi" I opted for the half inch tools. I am working on a vase that may be six inches deep and I get a high pitched screaming vibration like crazy --mostly with the almost straight tool but some with the semi-swan necvk and even some with the swan neck.
Whe I carefully slip my Sorby Hollowmaster in there, knowing it can only go in and down so far, I don't get any vibration.
I went out this morning and slipped the almost straight Kelton inot my Tru-Grind and after some fiddling got a good pass on the edge. What a difference! Still a little vibration but so little as to be almost unnoticable.
the other thing is that despite the fact that the Sorby cutter seems as narrow or narrower than the Kelton, I'm getting a clean cut with it. With the Kelton...even rolled a little to shear scrape...I'm getting ridges.
[sigh] I thought the Sorby was supposed to have the steeper learning curve.
DW
ArtLiestman
>I've never used a Sorby Hollowmaster, but it seems that the tool has a 3/4" bar. Are you using the 1/2" Keltons? If so, they should be able to go 6" deep or a bit more before vibrating very much. If you're using the 5/16" Keltons, then you are beyond their limit. As a rule of thumb, you should be able to go to a depth of about 15 x diameter with a given bar size. With the 5/16" tools, that would be about 4 5/8". Of course, it seems to vary a bit depending on the type of wood, whether it's green or dry, whether it has knots or inclusions, and so on. I use all of the sizes of Keltons and have excellent results with them.
DWFII
>Art,
Thanks...must be something else I'm doing wrong then cuz it's the 1/2 inchers I'm using...there's one size bigger isn't there? Probably what I should have got. Yes, I think the Sorby is 3/4 but it's not even half round. There ought to be as much metal in the 1/2 inch Kelton as in the 3/4 inch Sorby, wouldn't you guess?
DW
Greg Jensen
>It would be best to use a Medium slip stone or Hard Arkansas. The diamonds do not work well.
A course diamond is 220 grit which is a little to fine and will not raise a good burr.
Swipe upward riding the stone on the bevel of the tool. Do not worry about the hollow grind from the factory it is there because of the equipment used to sharpen the tools. If you have rounded over the bevel lightly touch them up on a grinder to get them back to new. Then use the slip stone.
