Vacuum Chucking _Nova Vacuum adapter
DD
>I have built a vacuum chuck for my Nova DVR but am having a problem trying to source a vacuum hose with a 1" internal diameter that will fit over a Teknatool vacuum adapter for the DVR/3000. Would appreciate any feedback on what others have used with this type of adapter. Thanks.
DD
Re: Vacuum Chucking _Nova Vacuum adapter
Jorge Castaneda~Downeast Maine
>DD,
Why an inch of internal diameter?
All the rigs I've seen use 1/4" air hose, or close to that.
Jorge
Bob Tabor
>I driller and taped the inside of the adaptor to 1/4 pipe thread and use a 1/4 in air hose quick connector. I have not had any problems with this setup andit works great.
Now that's very clever. However, the OneWay Rotary
Garrett in Victoria
>Adapter for vaccum chucking has an insert for the DVR3000 handpiece thread. I kept mine when I sold my General - it's an excellent piece of equipment - and OneWay sent me the new insert.
Do NOT, however, buy the Teknatool adaptor, unless you intend to use it with a high air volume source such as a shop vac. The seals aren't tight enough for small pumps.
Cheers, Garrett
Phil Joines Krum, Texas
>Don't know if it's the same as the 3K adapter. I just sliped a small shop vac hose over it. Very loose but with the high volumme air flow it didn't matter as long as the pieces were 5" or more in diameter.
Darryl Hansen
>Hi DD, I used 1" plastic tubing with the reinforced threads in it from Lowes. some times it collapses but I tied cable ties around to keep it round. Works just fine. I also plugged up the hole in the Nova adaptor. Also had to wrpa the adaptor with duct tape it make a tight fit. I just slip the hose off and on when needed.
DD
>1" internal diameter matches the external diameter of the Teknatool vacuum adapter. I am using it with my shopvac and it needs a bleed hole to permit some flow of air into the shopvac (Sears actually). The vacuum adapter comes with a pre-drilled hole (untapped) to provide the necessary bleed air. There are two other holes (tapped) to secure the vacuum hose to the adapter or to provide additional bleed air.
DD
Re: Now that's very clever. However, the OneWay Ro
Colin Spencer
>Garrat
Sorry I disagree with you. I have the Teknatool vacuum adaptor and I use it with a Gast pump without problems. I just filled the 3 holes with 8mm grub screws and sealed them in with silicon and put a large rubber O ring in front of the bearing in the hand wheel. I can pull up to 24in with this etup which I understand is about usual and to date have not had any issues. Certainly outside of the US the Teknatool adaptor is much cheaper than the Oneway.
Colin
>Colin That's exactly what I did. I have been using the Nova vacuum adaptor for years. I use a piece of closed cell foam to improve the seal between the bearing and the handwheel. It works so well I had the handwheel on my Powermatic bored to take the same bearing.
I guess I should have inserted the phrase
Garrett in Victoria
>"as designed and built". Almost anything can be made to work, but Teknatool products - I have the DVR 3000 and SuperNova Chuck - are usually good out of the box. The vacuum adaptor was designed for a shop vac and does that well. Good work-arounds have been suggested for low volume units, and I'll collate them into an article for the Turning Section. And I agree, of course, that it is relatively inexpensive.
Cheers, Garrett
