Have a question? Ask Woody!
2 bandsaw questions
2 bandsaw questions
2 bandsaw questions
Gary Evans Tallassee, TN
>I'm putting an old Delta 14" bandsaw back into service. My questions are:
At what point do the tires NEED to be replaced? Is "hard but not cracked" acceptable?
Is 105" the correct length blade for a 14" Delta with a 6" riser block?
Thanks,
Gary
Re: 2 bandsaw questions
>Gary 105 is the right size. I don't know how hard the wheels can get. Mine are pretty hard. They came with the saw and I got it used. I'm pretty sure they are the original ones. They are much harder than the new tires I bought but the saw seems to work fine now. I plan on going over the saw sometime this winter and tuning it to the max so I went on and bought tires when I found a sale.
Bruce in Saint John, N.B. Canada
>I can't comment on the tires Gary as my saw is 10 years old and the tires are still not hard or cracked. If your saw is equiped with the riser block you should be using 105" blades, maximum and minimum lengths are 106 & 103 1/2 inches. Trust this is the information you require.
Bruce in Saint John N.B. Canada
