Cracks in Cherry
Cracks in Cherry
Cracks in Cherry
Dawn Adams
>I thought I stumbled across a great find about a month ago when I found a distant neighbor finishing off a large cherry tree in his yard. He had already hauled away the small stuff, but the trunk was all mine. For a cherry, I think it was quite large - 16" in diameter. When I got the wood home, I put anchor seal on it. When I had the time to rough turn it, I cut it into bowl blanks, turned it, sealed the endgrain of the bowls with more anchor seal, and then placed each bowl in a paper bag with some of the shavings. Within 2 days, all 3 of the bowl I have turned so far developed very large cracks in the base of the bowl (on the outside only so far). How frustrating. I have read that cherry is prone to cracking, but is there anything I can do to the one remaining chunk of wood when I turn it so it will not develop cracks? Also, any suggestions on what to do with the 3 bowls that already have cracks? Thanks in advance.
Re: Cracks in Cherry
Carole in VA
>Dawn, are the cracks radial or do they follow the growth rings? Is it wild black cherry? That stuff is prone to ring shake and once I see that in a piece, I toss generally toss it. Sometimes I boil fuitwood roughouts before using the alcohol treatment to dry them. That seems to help.
Kevin Gerstenecker
>Dawn, look up Dave Smith's Alcohol drying process in the "Articles" section and dry your green roughed out bowls using Dave's process. I have turned and dried many, many green Cherry bowls using this process, and I have not lost a one. Actually, I can say that for all the bowls I have used this on, with the exception of one Osage Orange Bowl. The Osage was very green, and I left the walls too thick, and I got some severe cracking. Since then, I have even dried Osage without problems by thinning the walls some. I have tried several techniques with roughed, green bowls, and I have almost 100% success using the "Dave Smith Alcohol Drying Method"!
As you probably know, Cherry will check almost right before your eyes when you cut it. It is imperative to get it cut into blanks and seal it as soon as you can after cutting. I have found I have the best luck just cutting the logs into halves, removing the pith. I then Anchorseal both ends, and about 2" or so down the face grain that is exposed on either end of the log section. Your mileage may vary, but this works great for me on most woods.
adrien
>What the hey: if you have a supply of Tightbond or a similar glue, make a 50-50 solution with water and drop the cracked portions (if not the whole piece) into the solution and let sit for a few days. Sometimes the wood swells back up and closes the cracks....
Curt Fuller
>I live in North Ogden, Utah, a town that has so many cherry trees that our 4th of July celebration is called Cherry Days. One thing I've learned is that the beautiful cherry wood funiture you see, the cherry turnings, etc. are not from the same tree as the delicous Bing or Lambert cherries are from. My guess is that your neighbor was cutting down his cherry tree because he was tired of the cherries falling on everything and staining, so it was a cherry fruit tree. I to have tried many times to use fruiting cherry from the local orchards and had your same experience. I've been back east a few times and seen the black cherry trees that grow wild and produce cherry lumber and turning stock and they aren't the same tree. Orchard trees will produce some beautiful wood but it takes a magician to keep it from self destructing.
>Dawn I used to have a problem with all my green bowls checking at the bottom and finally learned that I was leaving the bottom too thick compared to the rest of the bowl. I leave a tenon on the bottom or the chuck but I've reduced the size to about 1/2". Also found out that the bottom of the bowl moves less than the sides so I make the bottom thinner on the rough out. This leaves the total thickness of the bottom + then tenon about the same as the sides. This evens out the drying and I don't have problems with the bottom tenon spliting anymore.
JKJ in East TN
I've wondered if it would help to hollow the tenon somewhat (but still leaving a wide enough ring to grip strongly) before reversing and mounting in the chuck.
Fruit and wild is the cherry I get around here.
Dave Smith, Longview, WA
>Hi Curt,
I have several fruit and wild cherry turnings that were dried using the alcohol method. The process is fast and predictable. In most cases the roughed out bowl is ready to finish turn in 2 weeks. With all that cherry in your area it is worth a $10 investment in a gallon of denatured alcohol just to see if it works.
Dave Smith
Way past my bed time in Longview, WA.
