Re: Chainsaw Blade Question.
Tim Conlon
>You want info on ripping chain? read on! BTW - the main danger involved with any chain is if you get the tip of the bar into the wood, then it can cause the bar pop up and back at you. But if you are careful to keep the tip out of the wood and a firm grip on the saw and a well operating chain brake, there is no reason to be afraid of this chain. But for occasional ripping of small diameter logs, ripping for turning blanks can be done with a SHARP crosscut chain. Invest in the proper size round file and learn how to sharpen the cutters and file down the rakers. A SHARP chain will rip nicely.
This is good for starters but Allan doesnt sell chain:
http://www.chainsawsforsawmills.com/sawchains.htm
Granberg sells ripping chain, here is a LOT of detail:
http://www.granberg.com/ripping_chain.htm
Check out www.baileysonline.com or 1800 322 4539 and request a free catalog. They sell the chain you are looking for. Search on their site for part WP375 30RP.
from the part description:
"Ripping chain is specifically designed to cut efficiently with the grain of the wood, unlike standard saw chain. It is most commonly used to slab logs, burls and stumps. Most people use it with chainsaw powered sawmills such as the Alaskan Sawmill (Part Number 46776)or Beam Machine (Part Number 46100). Ripping chain gives you a smooth, consistant surface when cutting parallel to the grain of a log. On the contrary, standard saw chain is designed to sever wood across the grain, and when you saw parallel to the grain, your cutting speed falls dramatically, and your sawn surface becomes very rough.
30RP is our most common ripping chain. This ripping chain is used on bars from 16" to 32" long. The top plate of the semi-chisel cutter is ground at a 10 degree angle, while the side plate is ground at a 75 degree angle. 30RP is .375 pitch x .050 gauge (1.3mm). 30RP fits saws using Oregon® 72 series and Stihl® 33 series chain. 30RP chain sharpens with a 7/32" round file or 3/16" grinding wheel. This chain is recommended for milling purposes only. It is not designed for standard hand held use.
Priced per Drive Link
We will build a chain loop with the total quantity you enter
WARNING:All WoodsmanPRO™ saw chain is capable of kickback and could result in serious injury to the saw operator or bystanders. Do not use this chain unless you are experienced in dealing with kickback."
-Tim
