Quick question about CA glue
Kevin Turner
>I've never used CA glue , that I know of. Which should I purchase? is there a certain brand name that is better than the others? Thanks KevinT in T Bay
Re: Quick question about CA glue
Ryan McMullen
>IMHO they are all about the same. Now what consistency you need to use depends on the situation. For crack sealing I use the thin CA, for securing a waste block to my work or for crack filling I use medium CA. I have yet to use thick CA, but I'm sure at some point in the future I will.
Ryan
Bill Howatt
>Kevin,
I have used the Hot Stuff from Lee Valley and whatever Woodchuckers (Toronto) sell and they both work well. I agree with what Ryan says and I have used the thin the most followed by medium. I haven't used much thick at all.
Bill
Kevin Turner
>Thanks Bill and Ryan... I have a bowl that the knot has a small branch steming from the bottom of a bowl (Ash). The heart wood was soft and could have fallen out....Hopefully this will stop it,,,Again Thanks, KevinT in T Bay.
adrien
>I like CPH International, 611 S. Catalina St. 400A-B in Los Angeles, CA 90005, phone 1-800-900-GLUE (4583). Prices are good, service good.
Ron Parsons SE NM
>I use thin is I need penetration. Medium for gluing most stuff together. The medium set slower compared to thin of the same stuff. I bulk buy through penturners. Also I disagree that all CA is the same. I get Apollo 2000 and it has much better coating (surfactant). But that is for a special use. I don’t believe that for most uses CA is CA each has its own set time and thickness. BTW accelerator weakens CA and I have been told that humidity also affect it’s strength.
re Quick question about CA glue
Dennis J. Gooding
>Kevin, you also need to know how to take care of the CA glue. After opening the glue, discard the cap and leave the bottle open to the air. After each use, bang the bottle down hard on a surface to make the glue fall back into the bottle, leaving the neck open for air to enter. Treated this way a bottle will keep for months. If you cap it after using it the glue will set up in the neck of the bottle, quickly plugging the neck. Dennis
