Sharpening mini tools?
Ed Kelle
>Looking for the best way to sharpen my mini tools, mostly having trouble with the gouges. As much as I try to go gentle, I seem to be taking off more metal than I'd like, plus I seem to change the profile way to easily. It's hard enough just to see the tip of a 1/8" gouge so touching it to a slightly unbalanced grinder does not help.
Is there a better/more consistent way to sharpen mini tools? Maybe just hone them with a stone? Thanks
Re: Sharpening mini tools?
>Ed I do 2 things depending on the size of the gouge. I set everything up on the grinder just like normal, turn the grinder on and then turn it off. when is slows way down I sharpen the gouge with very light pressure. These are my 1/8 inch gouges. My 1/4" gouge I can usually sharpen on my slow speed grinder with very gentle pressure. On my really tiny gouges I use a dremel with a small white gringing wheel. I clamp the dremel in a vise and then with a pair of magnifier glasses I grind the tool. I slow the speed down a lot. This is my smallest gouge to date but I'm planning on a smaller one for a future project. These don't have a flute. I found out that they cut better and stay sharp longer without the flute. Not to mention that they are easier to make.
Ed Kelle
>Thanks John. I will try your suggestions. You are making one even SMALLER than that one? Wow!
