12" tool rest for Jet mini lathe?
Robert Savit
>Does anyone have a source for a 12" tool rest for a mini lathe (5/8" post diameter). I know about the bestwoodtools post and the one made by woodcraft, but I'm looking for other options. Any suggestions would be appreciated.
Thanks,
Bob Savit
Re: 12" tool rest for Jet mini lathe?
JimQ
>Check Delta customer service, I think they make one for a bunch of $$$.
JimQ
Bob Lemon Sacramento Ca.
>The new Penn State catalog lists the 12 inch tool rest for the Jet lathe for $14.95. (#CLT12JE)
Re: 12" tool rest for Jet mini lathe? *LINK*
>Best wood tools has one.
http://www.bestwoodtools.com
Two_ton_tommy
>The PSI 12" tool rest is very light weight. Non-aggressive spindle turning is about all it is go for, if that. You have to have a very very light touch particularly the further away from the post you get.
JKJ in East TN
>Do you know anyone with a welder? I used two pieces of round steel and built a long rest for my mini in about an hour or so, most of the time spent grinding the post to nicely fit the top rod. (In retrospect, it would have worked fine just butting and aligning the pieces and welding, but hey.)
The cost was less than $1.00 since I already had bought steel in quantity. Some people like to use an angle iron or angled flat bar for the top but the round works fine for me.
