Casting Pewter Rings on Small Turnings *LINK*
Garrett in Victoria
>You Might Like This New Article
Pewter
Re: Casting Pewter Rings on Small Turnings *LINK*
Peter Charles Fagg (UK)
>Garrett, a very interesting article, I wonder though with the heat of the Pewter does any burning occur of the surrounding wood?
I ask because I make dishes with a Pewter ring inserted that is engraved for special events.
The low melt Pewter, I have been told, is unsuitable for the engraving and pouring a reasonable quantity of your type of Pewter makes me wonder if there would be heat transferance problems and subsequent burning? My dishes have a 9 inch ring 10mm wide x 1.50mm thick.
Regards Peter.
John Trant (Baltimore/DC corridor)
>I would assume that the amount of pewter to fill the large groove in Peter's plate would have sufficient thermal inertia (even though the starting point is relatively low for molten metal) that you would get some scorching. Perhaps the groove in the wood can be moistened to add to the wood’s thermal inertia and thus resist scorching. It looks like a neat idea.
Peter, how do you keep the ring from popping out of the plate? Is the groove in the wood is dovetailed or is it just glued with a flexible adhesive?
Thanks in advance for the info.
John
>John, thanks for the comments.
The ring is stuck into the groove with an epoxy that reputedly is capable of lifting 2 tonnes on a 1 inch circle. As for flexibility, in the 5 years that I have turned these, none have come out despite the variables of households and locations across the globe.
The whole process of using some form of Pewter casting intrigues me, but taking one point you made, is it not likely that moisture in a sealed groove (the poured pewter) is likely to burst out as steam?
Peter.
Garrett in Victoria
>Hi Peter
I edited but didn't write the article. It actually appeared on the Canadian Woodworking Forum, and I asked Darrell Larue for permission to use it.
I'll e-mail him and ask that he respond to your questions here.
Cheers, Garrett
Darrell in Oakville
Darrell in Oakville
>Peter et al
When I made the inlay on my pen I didn't see any appreciable scorching. There wasn't much metal involved, and the wood was quite dark to begin with. The lighter wood on the wand with the narrow band had a small amount of scorching, but that pretty much turned off. Seems like the outer edge of the wood is more suceptible to burning. The wand with the wider bands in the handle didn't suffer any noticeable burning either, even though there was a lot more metal involved. Still, the amount of pewter I was using isn't anything close to how much would be in your plate rings.
As far as trying to prevent scorching, I would not let molten metal contact wood that's even remotely damp. If your mold is full of steam, the metal will come right back out at you (Yikes!). When I did my pouring I wore my full face shield just in case.
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
>Darrell, thanks for the input I appreciate your efforts. I have noted your comments on moisture, I can only think it would have the same effects as when gas welding.
Thanks again, Peter.
