Lacquer over Danish oil
Stuart Johnson
>Can lacquer be applied over Danish Oil?
Re: Lacquer over Danish oil
John Trant (Baltimore/DC corridor)
>Yes, but make sure there is no (or very minimal) film built up and that the oil is completely dry. Give it a week at room temp.
John
Another thought
>If you are very concerned about adhesion, then use a coat of shellac between the oil and the lacquer. Don't go for a thick film of shellac. A coat of a 1 pound cut will be enough. Shellac is quite useful as a "universal" primer and sealer. It sticks to just about any finish and any finish will stick to it.
John
Re: Another thought
Stuart Johnson
>Thanks John, for the the input. I probably should have asked over on the other forum as I'm in the middle of making cabinets for the shop. The doors are Oak frames with Walnut panels. I used Walnut Danish Oil on the panels but want to stay natural on the frames. I think I'll just go ahead and give them a couple coats of Natural and spray the units with lacquer. This way I won't need to worry.
Re: Another thought
>In general, I agree with using shellac between the oil and the lacquer. You'd better ask your lacquer manufacturer for a detailed recommendations, however. Some brands of lacquer (Qualalac, for example) require a sanding sealer (another lacquer-based product) in between to bond properly to even shellac. I'm not sure whether the sanding sealer is needed to bond to a clear, dewaxed shellac, since I usually use orange shellac.
