Grinding Jig
Grinding Jig
Grinding Jig
Cody Carse
>Hello all. This is my first post. I want to start off by saying this is an awesome site! I am a new turner and was wanting some advice on buying a grinding jig. The problem I have is that I have a 10" Baldor Grinder. I have been having problems getting a consistant fingernail grind on my bowl gouges when grinding freehanded. I was looking at buying possibly the Wolverine setup and was wondering if it will work with my grinder? I have included a pic of my grinder. I appreciate any help and advice you can give!
Re: Grinding Jig
Re: Grinding Jig
>Cody It will work. You will have to put a board between the grinder base and stand. The wolverine needs to be mounted below the wheel and centered on it. I don't remember the exact dimensions but it tells you in the instructions.
Re: Grinding Jig
Re: Grinding Jig
Cody Carse
>Thanks a lot. Will the standard package be enough to do my bowl gouges or will I need to get the Turner’s Fingernail/Side Grinding Jig in addition? Also, do you think the wolverine is the way to go or another brand? Thanks
Re: Grinding Jig
Re: Grinding Jig
>Cody, I made a homemade version of the Wolverine Gig. I used a steel square tube from the big blue box and centered it under the wheel. John is right, you will have to have a board under the grinder to attach it to, but it will work. I have one side set up to do the Ellsworth grind on my bowl gouge and I leave it alone. On the other side, I have another steel tube with a Tee on the end. The tee gives me the spread I need to sharpen my skew. In the center there are two little blocks that a tool handle fits between and I use that for sharpening my roughing gouge and parting tool. I have a mark on the steel tube that tells me the right distance from the wheel to get the angle right. I also left one of the original supports on the grinder and it remains set at the angle for my scraper. I have all this on one of the low speed grinders from Woodcraft. With one tool I sharpen just about all my turning tools, with minimal changes in the setup. I looked at a Wolverine setup, but it was fairly expensive. This thing did not cost me as much as the gig for the Ellsworth grind. I have about ten dollars in it all together and it works well for me. The Ellsworth chisel would be the last to go, I do about eighty percent of my work with it. Also, grinding with a gig is much better than trying to do it freehand, at least for me. I can set the chisel in the gig and grind it and return to the lathe in seconds and the grind is repeatable and accurate. I would waste a lot more steel grinding by hand.
I think you will want to get stones made for high speed steel, if that is what you are using for tools. This is another whole discussion.
Re: Grinding Jig
Re: Grinding Jig
>From your description you will want the fingernail jig as well. Most of the other gouges are fairly easy to do by hand but the bowl gouges take considerable practice.
Re: Grinding Jig
Re: Grinding Jig
Don Tewell
>Barry,
Could you supply a photo of your home made set up? I'm new to turning and don't have the extra dollars for a Wolvering jig or a Tormek but don't feel qualified to sharpen by hand. Thanks.
Re: Grinding Jig
Re: Grinding Jig
Earl Eyre
>If you do a search of past posts you will find many places to get plans for homemade jigs. They work great. And I agree, a jig is much better than freehand, unless you are an expert sharpener.
Re: Grinding Jig
Re: Grinding Jig
Chas
>This is a thread showing details of a Fingernail Grinding Jig I made.
http://www.ukworkshop.co.uk/forums/viewtopic.php?t=4443
It may be of use to you.
Re: Grinding Jig
Re: Grinding Jig
Cody Carse
>Wow, great post, thanks a lot. Just what I was looking for. I think I will be making one of those this weekend instead of buying the wolverine.
