3 jaw chuck *LINK*
3 jaw chuck *LINK*
3 jaw chuck *LINK*
Bruce, a MN Galoot
>Grizzly markets a 3 jaw chuck, Woodstock International 3-Jaw Chuck, which is about the price I can afford right now. Does anyone have any experience with this, is it of reasonable quality, or can you suggest one better?
Thanks.
Bruce
grizzly's chuck
Re: 3 jaw chuck *LINK*
Re: 3 jaw chuck
Fred in NC
>That kind of chuck does not work very well with wood. It is a copy of the chucks used in metal lathes.
Phil Joines Krum, Texas
>Fred's right, the contact area isn't large enough on the Griz for wood holding.
This one fron PSI is in the same price range. It fits 3/4x16 and 1x8 spindles.
PSI utility chuck
Re: 3 jaw chuck
Bruce, a MN Galoot
>thanks much.
will it hold metal rods, too?
bruce
Grizzly 4 jaw Vicmark copy.... *LINK*
Rob Ceraso
>Bruce -
Grizzly also sell this one which is only a couple of dollars more than the one you mentioned. I don't have this chuck but I know a few people on this board do as it was a topic of discussion when it first came out. And from what I remember, the reviews were pretty good.
Anyone else want to comment?
http://www.grizzly.com/products/item.aspx?itemnumber=h6265
Re: Grizzly 4 jaw Vicmark copy....
WOODNUT358
>I agree,for a few dollars more I would get the 4 jaw chuck.I have a Oneway Talon and love it.I just ordered the one from Grizzly.I also heard nothing but good reviews about this chuck.Plus it's half to less than half for the chuck.
Re: 3 jaw chuck
>Bruce What are you trying to do? most projects can be done without a chuck. I would be glad to describe how it can be done if I know what you need to do. The 3 jaw chuck you are looking at is for metal work and will hold round metal rod quite well. The back of the chuck may not be threaded for your lathe.
Someone already mentioned the Grizzly copy of the Vicmarc chuck. It is an excellent buy. It was $100 shipping and all. John
Re: 3 jaw chuck
>Not very well. The chuck in you're original post is for metal.
Arch
>Hi Bruce, Not to sound condescending, just a caution. Be sure to buy a self centering 4 jaw scroll chuck, not an independent sliding 4 jaw chuck..._regardless of the savings.
Okay, here's the deal...
Bruce, a MN Galoot
>I always get into trouble when I don't include enough info to start with. Here's the rest of the story.
My son has asked me to make "some" pool cues. The instructions I've seen so far have you start out by very accurately boring a hole in the length of the shaft and then threading in an insert. Into that insert you screw a bolt or other threaded object. You turn the shaft by grabbing onto that bolt.
I don't know if it's hype or mystique or the absolute truth that cue stick makers do not turn a finished handle in one session. The stuff I've read indicates that they will start with a blank, get it round, and then let it rest for a week or two before peeling off a little more. The idea is to allow some time in which the wood will resolve any internal stresses. It might take 8 - 12 weeks before the handle is complete.
The only way to grab that bolt with repeated accuracy is a chuck similar to the one in Grizzly, and I agree that the Vicmark one looks better.
If there is some other way to do this, I'm sure open to suggestions.
Thanks.
Bruce
Ian
>I bought the grizzley chuck about 6 months ago, along with the larger jaw set, haven't regreted it.
IAN
