Re: Stabilizing handle *LINK*
Phil Joines Krum, Texas
>There are several ways to make them.
The first way to use cold rolled round bar. The bar is bent using heat into a 26" x 7" rectangle with a nub sticking out long wise at one corner.
After making a number of them that way I found that using square stock made it easier to mount a laser. The nub is heated and hammered round. With careful work the rounding can be done with just a hammer but finishing with a swag, if you have one, it more accurate.
My latest method is to use rectangular tube with the nub welded in. The advantage is being able to use nutserts to mount the laser and the handle can be capped and filled with lead shot or sand.
To connect the handle to the boring bars solid, set screw motor couplers work fine.
The diameter of the bar stock will determine how deep you can turn. Depending on how light you're touch is 1/2" will go 9", 1" 18" etc.
It's a good idea to drill a hole in the back end of any handle. Drop a nail or bolt in the hole to keep the end of the bar from falling out of the support.
There are two ways to make the rear support.
There instructions on Craft Supplies USA's site. Look under the Jameson system.
I make them like the old style banjo. This is for lathes with a 1" tool rest shaft: A 1 1/2" or 2" x 1/2" bar has a 1 1/4" inch hole is drilled in one end. Cut off and weld a piece of 1" black iron pipe in the hole. Weld the slug from the flat bar to the pipe near the open end. Drill and tap a bolt hole for the locking handle in both the slug and the pipe. Drill 3-4 holes down the length of the flat bar to secure it to the bed. Using 2" x 1/2" bar stock make a locking plate to go under the bed. It needs a threaded hole for the locking bolt. Use two 3' pieces of 3/4" or 1" square stock to make the tool rest. On one end weld a piece of 1" round stock 14" from one end of one piece. Drill holes in both ends of both pieces for threaded rod to hole the pieces just far enough to hold the handle without being sloppy.
This style of banjo can be used along with the lathe's banjo to support a long tool rest for spindle turning. It also allows longer pieces to be hollowed by hanging the rear support off the end of the bed.
I'll be bringing several hollowers to the BBQ this weekend for people to play with.
Jameson instructions.
