Is Anchorseal enough?
Ted Owen, Pittsburgh
>When you rough-turn bowls and apply Anchorseal, do you normally then leave them out in the air, or even with the Anchorseal should you put them in plastic bags?
Please note I'm not asking for an honest appraisal of whether my turned bowls belong in garbage bags.
Best, Ted
Re: Is Anchorseal enough?
Jim Pugh, Ohio
>Actually Ted, as soon as the Anchorseal is dry they should go into brown paper bags and the end folded over and held shut with a clothes pin. The plastic bag will not allow the moisture to wick out and I only use them if I'm holding the turning for a very short time before doing something else to it.
Oh, and write on the folded over part of the bag with the type of wood and the date you put it into the bag. Look at the turning every few days for about 3 weeks. Put some ca glue in any cracks you see forming. After the pieces appear stable, put them out of the way for 6 months to a year.
Norm Smith in Nova Scotia
>Hi Ted,
I coated my rough turnings with anchorseal and put them on a shelf in my garage for 6 months or so. I have lost a few but my loss was minimal. I dont bother with the anchorseal anymore as I prefer to soak in Methal Hydrate (same as denatured alcohol) overnight and let them dry in a paper bag for a week than on a shelf for a week, Works great.
Norm
Jim King
>Why dont you just try boiling one bowl for three to four hours and let it cool in the water over night. Then set it anywhere to dry for a few days and finish it. It is so simple I dont understand why more people dont try it. No wax, paper bags , clothsepins, just let it happen. Try a couple of bowls and it will give you a new outlook.
CapeMayMike
>Hi Ted,
After rough turning I seal the end grain in and outside of the bowl and put them on a shelf, no bag, with room to air dry for about 6 months, most all of them survive. The most problematic has been cherry, besides the expected warping I sometimes get bad cracks. Other species have been fine.
Re: Our hardwoods aren't as hardy as yours, Jim.
Al Crandall- NE of Indy
>After reading your post about boiling and letting the blank dry in the hot Amazon sun, I tried it with a couple of mulberry bowls. They cracked so badly after 24 hours that I am surprised that I didn't hear the report. I have had limited success with boiling and bagging or boiling and alcohol soaking, but I think our woods need more TLC than yours. You guys put the hard in hardwood.
>Jim I looking into it but just can't justify the expense of heating the water. Don't really have the place to do it with a wood fire and I don't have pot big enough. Wood is free around here and I lose a fair amount but it didn't cost a thing except gas in the truck and chainsaw.
The same is true for me on the Alcohol issue. I don't want to buy or store that much alcohol. It's much easier for me to just turn them, coat them and throw them on the shelf. If they check I'll either toss them or make something else out of them.
Jim King
>Al: I find your comments very interesting. Never having turned wood from my own country I have no experience with it. But here we have to boil the wood when fresh turned and dry it or it tends to crack at a later date from a week to a year later. We cannot let our unturned blanks set unprotected or most will hairline crack or go wide open if dried to fast. I have continuous problems with people not turning the blanks when they buy them but instead letting them sit in the shop to dry without protection as if they were a temperate range wood. Tropical species from my experience have to be turned without trying to wait for the blank to dry. The majority of our turnings now go to the States and to insure that we were going to sell a good product we spent three years trying every process known to be sure that when one of our turnings reached the dry climate of the States it would not crack. It turned out that if we sent a turning by air that was the first test as planes are notoriously dry and even a few hours flying cracked our first pieces.
Boilng fresh turned blanks was our answer.
JKJ in East TN
>I coat all over and stack loosely on a wire shelf.
Bob Clancy from NM
>Simplicity is good ..... I rough turn and put in bird-seed or feed sacks, the three-ply paper (no plastic liner!) bags, that hold 20 to 40 lbs of feed. I get most of mine from a neighbor with horses. Sometimes double up the bags for 6 plies of paper total. A number of bowls can be put in one bag.
No Anchorseal, no boiling, no alcohol. Works great.
JKJ in East TN
>Hey, I'll try the bag idea - I have a constant supply of these bags from chicken and goat feed. That would be a lot cheaper than the anchorseal!
Thanks, everyone...
>...I'll try some of those ideas. Appreciate it.
Best, Ted
