Resizing pics
Resizing pics
Resizing pics
CapeMayMike
>How do I resize, that is to say, make smaller, a pic in order to post it here?
Thanks!
Re: Resizing pics
Re: Resizing pics
Bill Stehman ... AZ
>I use Microsoft's free Image resizer power toy... simply right click on any photo and select the size. Search MSN download site or I may still have the exe... it was small about 500k. If you have a newer version of XP it may already be intalled...?
Re: Resizing pics
Re: Resizing pics
Bob Lemon Sacramento Ca.
>Mike, If you download 'Photofiltre' (free) (spelling is correct!), you will have a very powerful, easy to use, photo program. After importing an image, right click the mouse, one of the options is 'size'. Increase or decrease in either pixels or inches the size. Also adjust the brightness, contrast, sharpness, etc. When you have the picture looking the way you want, right click again, click 'save as'. It will ask for a destination, I usually save to the Desktop. The image does not go directly to the desktop, instead you get another window which allows you to check and set compression. After setting, click OK and the picture will go to the destination folder. It will still appear in photofiltre. You can click on the 'x' to close the picture.
For posting on WC, a maximum of 640 pixels in width will give a good size for viewing. The file size should be no more than 40K. This is very easily adjusted.
Bob
Re: Resizing pics
Re: Resizing pics
>Mike, Forgot to mention when setting size, you can change the number of pixels per inch. Change it to 72.00. This gives good resolution on a computer screen.
Re: Resizing pics
Steven Antonucci
ditto
steve antonucci
Re: Resizing pics
Re: Resizing pics
Jeff
>Another way is if the picture is a .jpg file then open it in Paint and goto the Image "button" on the tool bar and select Stretch/Skew... and stretch the image by something smaller than 100% then look at the Attributes... in the Image "button". When you reach a size of about 5.92in X 4.44in then I know WoodCentral can upload it. The other ways probably work a little better and have more options but this way you don't have to download anything, and once you do it a couple time it becomes second nature.
Re: Resizing pics
Re: Resizing pics
CapeMayMike
>In an effort to avoid downloading and simply using what I already have I'm trying your suggestion. However I'm getting a "sharing violation" message when I try this???
Re: Resizing pics
I got it
CapeMayMike
>Thanks guys!
