varible transformer
bob lyon
>Hi-I have a jet mini,one of the first ones.Was always going to use it,but didn't.Can I put a variable speed transformer and change speeds that way.Thanks BL
varible transformer
bob lyon
Re: varible transformer
Brian Hahn in SW Wisconsin
>Variable speed transformers (and solid-state speed controllers) work by varying the voltage, which works great with universal motors -- routers, electric drills, shop vacs, sanders, etc.
However stationary power tools like table saws, band saws, drill presses and lathes normally use induction motors. The speed of an induction motor is controlled by the line frequency, not the voltage. AND if the voltage is too far from the motor's rated voltage you will likely run into some serious problems -- i.e. time to buy a new motor.
bob lyon
>Hi Brian-Thank you for the info.I suspected as much but wasn't sure.Thanks again BL
