We value your privacy.
>I'm not sure who "invented" this, but I give credit to Bill Grumbine for my knowledge of it. It's probably the biggest one of these I've seen, and I made it in about an hour (in between a bunch of other things. One thing I will change is that I will pad the outer "jaw", since it left some marks on my bowl (more $%@&!% sanding!)
The bowl is about 1/2" too large to swing over the bed, so I needed to create a secure chucking method to turn the foot. I used MDF because I had it, but I'd assume plywood is better. There is a smaller plywood circle screwed to the back of the bottom sheet of MDF, since you can't "thread" MDF (tried that first). The hole in the middle threads on to a screw center in my chuck.
It worked pretty well for a few minutes work. I might just make a "permanent one for big bowls.
>Here is a quick shot of the bowl interior. A few bug holes have been filled, as well as a crakc or two. Soaked in mineral oil, still a few minutes of hand sanding left.
>I'm with Rick. I have my bolts going the other direction, though it required a "riser" of sorts so they didn't hit the motor on my Jet 1236 and it's... akward motor placement. I also used round-headed bolts and recessed them a little in the plywood.
>I don't remember whose idea this is but you might give it a try. Purchase some 3/4" tubing, split it and wrap it around the inside. I wonder if that type used to keep pipes from freezing would work.
>The first "donut chuck" I saw was when I visited pro turner Jack Straka near Hilo, Hawaii in 1986. I don't know if he invented it or not. I came home and promptly made one for myself.
>I thought about doing that, but this was a "proof of concept" for me. In a nutshell, version 1.0. Now that I know it works, I'll probably make some other modifications in addition to the bolt direction.
Already mentioned the padding, and I'd probably want to use something with some grip (rubberized?) I'm also thinking that I'd knock the back screw plate off for a tenon and double it up for stiffness. And I might even try drilling my holes evenly the next one.
>Steve, I took a different approach. I have a set of Cole jaws for one of my chucks, but they have a capacity of about ten inches. That was fine when I had a lathe with a twelve inch swing, but when the lathe got bigger I needed a bigger grip.
I made a set of "hooks" out of 1" flat steel bar stock from the big blue box. I cut eight pieces about five inches long and bent them past ninety degrees, creating 1" by 4" hooks. I made a little fixture for the drill press that let me accurately drill holes spaced from the elbow. I dipped the griping end in some of that rubber they have for tool's handles.
They work great. Better than the rubber bumpers that came with the jaws. I just screw them to the Cole jaws with the rubber bumpers. Since they will extend 3" past the last bumper, they increase the grip to 16" which works for me, but you could make them bigger. I'll post a picture is anyone cares.
I bet you could put four of them directly on the chuck slides. The problem with this setup would be that you would have to have a bunch of sets since the chuck only has an inch or two of adjustment.
>In this setup the hooks are not set to their maximum and they are held in place by spare jaw screws, not the rubber buttons. I was turning platters that were very flat and the bumpers would have been in the way. There is tape over half the screws. I took half off for the picture, but the tape was there just to keep the screws from imprinting he platers. Normally, with a bowl, the bowl does not tout the screws or the bumpers. I am about to turn some square platers and I think theses will work well for that. They are much more secure than the bumpers and I use them even when the bumpers would work. Perhaps I need a smaller set, also.
I put two holes in them thinking they would need two screws, but they don't. If I made them again, I would set the second set of screws at some spacing other than those matching the spacing of the chuck to give me a "half" step if I needed it.
Dipping the ends in rubber was probably a good idea, but it was the most expensive part. The liquid rubber cost more that the strap of steel. We are still dealing with about $4 for steel and $6 for the rubber. This is the best thing I have done for those Cole jaws.
>>I find it funny how many of the "new" gizmos are actually very old.
Procedures, shapes, and finishes too! I posted this before but I still get a kick out of the friction polish observed in use on the lathe in 1590:
The first use of shellac as a protective coating appears as early as 1590 in a work by an English writer who was sent to India to observe the country and its people. Commenting on a procedure for applying lac to wood still on the lathe he writes "they take a peece of Lac of what colour they will, and as they turne it when it commeth to his fashion they spread the Lac upon the whole peece of woode which presently, with the heat of the turning (melteth the waxe) so that it entreth into the crestes and cleaveth unto it, about the thicknesse of a man's naile: then they burnish it (over) with a broad straw or dry Rushes so (cunningly) that all the woode is covered withall, and it shineth like glasse, most pleasant to behold, and continueth as long as the woode being well looked unto: in this sort they cover all kinde of household stuffe in India" From "Shellac; its production, manufacture, chemistry analysis, commerce and uses."<.i> London, Sir I. Pitman & Sons, ltd. 1935, pg. 3.
