Another Hollowform Question
JimQ
>Sorby makes the Hollow Master in 2 sizes, standard and Midi. For someone with a Delta Midi lathe, is there any benefit to the smaller Midi version now that the standard is on sale at WoodCraft for less than the Midi version(not on sale)? The Midi version uses slightly smaller bar stock, but similar cutters. The same is true for the Multi-tip shear scraper, Midi and standard.
JimQ
Re: Another Hollowform Question
>Jim You can't go as deep with the smaller bar, you get chatter so I would go with the bigger one just in case you want to do a deeper vessel.
Molly Winton
>Jim, John is right the smaller version can't go a deep. It all depends upon your needs. I'm getting the midi because I'm not concerned about the depth issue, but I want a shepard hook hollower that can get into a smaller opening. I like to have my openings no more than 3/4". If I want more depth I use my Stuart system that has a 3/4" bar. (Ahh, the flexibility of multiple tool ownership!!)
Ed Karch in No.VA
>Go for the heavest hollower that you can fit through the hole. It is amazingt how steel vibrates when you hang it out over the tool rest.
Gerald McGrantham
>Thanks for the heads up on the WoodCraft sale. Being my birthday today, my wonderful wife ordered the large and midi hollowing tools for me.
Thanks,
Gerald
Thanks for the feedback!
JimQ
