We value your privacy.
>How do you sand inside a vase that may be deeper than your fingers and with an opening no larger than two of your fingers firmly scrunched together? Or smaller for that matter?
For small openings, I use a Maple dowel that is rounded on the end, and has a slot cut into it on the bandsaw. I fold up a piece of sandpaper, and cram it in the slot, or wrap a piece of abrasive (usually cloth-backed) around in the correct direction so it doesn't unwind inside the piece. You can then rotate the dowel back and forth or round and round to keep fresh abrasive in contact with the wood.
For real small openings, I use a surgical hemostat to hold small pieces of abrasive. I got them from a lab where I used to work. Some catalogs sell 'em , and they're available wherever college-age people are found ;~)
For larger openings, there's now a velcro-covered ball on a metal rod that holds scrunched up velcro backed disks -- it can be used in a drill for power sanding.
Some people don't sand the insides, or at least, not much. I figure that if you can touch it, I ought to make it a pleasent experience !
>Make a stick shaped like a hocky stick as long as needed for the piece. Keep the short leg as short as posiable. You can either use PSA paper or cut a slot on the back side for a wedge to hold the paper.
>You can make this sander which attaches to your Sorby Hollowmaster. It's made from 3/4 inch thick neoprene foam. This is the same foam that comes with the micro-mesh kit. The shape is traced from the teardrop scraper that comes with a Sorby Multi-Tip tool and cut out on a bandsaw. Then coat the outside with thin CA. Attach self adhesive velcro around the perimeter and glue a nylon bushing in the center. Cut a two inch sanding disk in half and attach to the velcro.
The sander will go into a 1 1/2 inch hole. Swivel the sander to match the contour you are sanding.
>...is inversly proportional to the opening size. The smaller the opening, the greater the interior finish quality. My hollowforms with collars and 1/2" openings are sanded glass smooth inside. Go ahead and feel it yourself. Oh...can't get your finger into that 1/2" dia opening? Oh well, you'll have to take my word for it.
>This may be slower, but it works well on the bowl wall. It won't do the entire bottom, but it's better than nothing. This method is based on the same concept as a rock tumbler.
Mount the bowl on the lathe, put some gravel inside it and cover up the opening. Turn the lathe on at 100 or so rpm and let it spin for an hour or two. Obviously, shape of the bowl will dictate how much gravel to put in.
